Pyro probe location
Pyro probe location
I'm looking at ordering a pyro and looking for input on where would be the best location for the probe, pre turbo or post turbo. The truck has factory exhaust but im sure I will add 4" sometime in the near future. Also what temps I should expect to see, I do not run a tuner and do not have a tuned ficm. Picture would be appreciated if possible.
Thanks
Thanks
Mine is in the rear of the drivers side manifold and I have seen near 1400 when I wasn't paying attention. I try to keep it below 1300 when towing.
That is based on the temperatures given in the Tech Folder: https://www.ford-trucks.com/forums/9...-pressure.html
I drilled from underneath with a small bit and gradually increased the hole size so there were no large cuttings that could enter the manifold. Tap carefully with a greased tap and test often so you don't cut the thread too big and bottom out the fitting. You will need a tap holder with a 3/8 drive and a long extension. A pair of goggles is also a good idea, the cuttings will fall on you!
...I drilled from underneath with a small bit and gradually increased the hole size so there were no large cuttings that could enter the manifold. Tap carefully with a greased tap and test often so you don't cut the thread too big and bottom out the fitting. You will need a tap holder with a 3/8 drive and a long extension. A pair of goggles is also a good idea, the cuttings will fall on you!
Found this pic, not mine but similar:
https://www.ford-trucks.com/forums/1...l#post13128932
build quality is fine, I wanted 4 digit with no multiplier for the pyro so went with auto meter. Both are bright enough to see them in full sunlight. I switch them off, for the night trips. I have pre/post turbo same gauge, 2 sensors/switch. The post turbo has been over 800 in the mountain's and cools slower than the pre turbo sensor.
