Brake Pedal spring
Brake Pedal spring
Nathan - stock location - it hooks to a loop on the cover plate (between the block and the bellhousing) just about horizontal with the brake linkage. It looks like an extra bolt hole, but protrudes past the bell.
You're lucky! I had to crawl under trucks that had settled into the dirt at a local junk yard to find one that still had the springs connected when I rebuilt mine.
