239 Ignition Timing
239 Ignition Timing
Hi,
I am trying to get my 239 OHV up and running. But the mechanic that is going to help me doesn't know anything about Y blocks.
He needs to know the following:
1) Cylinder locations 1-8
2) Cylinder locations on Distributor cap
3) Distirbutor rotation (CW or CCW)
4) Tune Up Specs (points gap, dwell gap, spark plug gap ect.)
And anything else that you think is important that I forgot.
Thank You,
Thank You,
These links I think are what you are looking for:
Flathead Tuneup Specifications for 1949-53 V8 (239 & 255)
https://www.ford-trucks.com/forums/1...ng-issues.html
http://www.ford-y-block.com/assemblyerrors.htm -more for rebuilds but good to know info
1950 Ford 239 Flathead V8 Engine Specs
ignition timing and vac advance 239 flathead - Hot Rod Forum : Hotrodders Bulletin Board
hope these help, good luck!
Sounds like a good mechanic, and I'm not being sarcastic. It is good that he asks these questions and does not make assumptions.
Cylinder numbering.
So we are on the same page, the water pump is the front, the flywheel is the back, the distributor is the right, the oil pump is the left.
On the right bank, numbered from front to back, 1, 2, 3, 4
On the left bank, numbered from front to back, 5, 6, 7, 8.
Firing order 1-5-4-8-6-3-7-2
The distributor cap probably has a 1 near one of the terminals and that is where #1 should be. From there, follow the firing order, counterclockwise.
I don't remember the tune up specs, but I believe that is typical of any points equipped v8.
For stock cams, valve clearance, .019". About 1/4 turn of the adjuster screw loose from 0 clearance will get you real close.
Cylinder numbering.
Here is an image that might be helpful.
It was from this thread: https://www.ford-trucks.com/forums/1...lp-please.html
I'm currently putting together my 239 Y-Block. I'm an amateur so I'm going very slow and asking lots of questions. My thread is in my signature.
Here are the distributor specs from the shop manual:
asmith6
02-14-2024 09:18 AM
mcanacari
12-27-2018 01:15 PM
ReissL
06-29-2018 05:22 PM
64'F100BobbySurfer
07-27-2015 06:56 AM
