Coolant fountain
I'm just going to throw this out there as an idea for a fan. On my F150 we took an electric fan out of a Crown Vic and it fit perfectly into the shroud. Not sure if it will with these or not, but might be worth a shot. It didn't pull as much air as the stock fan but as long as you weren't in 95 degree weather stuck in traffic it was fine. There must be a ton of crown vics in junk yards.
Personally, I'd put a fan on it asap. Overheating the engine seems like a really risky thing to do for $100 if you can at all avoid it. Did you put a request in the new "Parts Wanted" sticky on this site? Somebody must have one laying around somewhere.
I won't let the truck over heat if it gets even close to the "L" I shut it down a new fan clutch is only 120 so I might just do that but it's getting a new t-stat and cap tonight and well see what happens I've read that if the temp gets to hot it should push coolant out of the cap and it was bone dry so I'm thinking the cap might just be locked up but a t-stat is good insurance and ill see what happens I'm also going to check the rad for cold spots and make sure it's flowing right
Ok so replaced t-stat and cap and I drove it around a little but it started to pour pretty hard so I stopped because I was either going to get to hot and end up on the side of the road in the pouring rain or the rain would keep it cooler then normal but when I was driving it around it was fine it got up the the "R" but I was in a 30 mph zone and it was after I had to wait on a train so I'm not sure if that was because it was sitting waiting on the train or because of the problem but the truck runs great no problems what so ever just this cooling problem
Received 3,697 Likes
on
there are no test strips to test for combustion gasses in the coolant(at least none that I know of) . there is test kits that have a clear glass jar with a tapered rubber end that fits where the radiator cap goes. than you fill it with the test solution and run the truck and then pull a vacuum on the top of the test bottle. if the test fluid changes color you have a combustion leak.
Capt.Schenk
06-24-2016 10:34 AM
westkane
1999 to 2016 Super Duty
05-01-2013 11:35 AM
