Occasional squealing while towing. Turbo? Something else?
Jeffreyt mentioned that his truck was squealing loudly when pushing hard while towing, and I've been chasing the same symptom for over a year. I'll let Jeff chime in to this thread and speak for himself, but here's how he described the problem initially:
My issue sounds the same. Only when towing, only when pushing hard, which means both boost and engine RPM are pretty high. Jeff thinks it's our turbos, and he might be right, but I'm not certain. I tested mine this morning, and it has no in-out or side-to-side play when moved by hand. I did see a "ring" around the turbine wheel when I looked at it this morning:
I thought, "that's it"! Except that I looked at a photo I took when I installed the ATS housing three years ago, and it looks the same:
I've got some other ideas, but need to run now. Your thoughts?
Mark
Originally Posted by jeffreyt
What I did run into was an issue with the turbo. Several times while accelerating hard or pulling a hill, I had squealing. Bad squealing. I'm fairly certain it was the turbine wheel contacting the housing. I immediately got out of it. Guess a turbo rebuild is in my future. That or a 38R... Or not.
Mark
Last edited by ScaldedDog; 06-14-2013 at 10:12 PM. Reason: Edited title to attrack more responses
My other thought was the alternator could be making the racket. Last summer when this started, I took the belt off any my awful Ultima alternator from O'Reilly spun fine. When I moved the shaft up and down, it rotated on the front bearing. The rear bearing cap had fallen off, and the shaft was loose there. I thought a new alternator would fix the noise, but when I started towing again this spring, the noise was back
Someone else mentioned that it could be the belt. Mine only has 3y and 17K miles on it, but the tensioner is the original, with 12y and 136K. It still feels tight, but I'm not sure how to test it. I did replace the idler pulley, and that did not help.
Mark
Mark
Still trying to run this down... I took the belt off this morning, and checked the various pulleys. The cheap chinese alternator pulley is fine, but I noticed the power steering pump pulley has some in/out play. I've never checked it before, so I have no idea if that's normal. Do any of you?
Mark
Mark
I have had this happen a few times too - It only happens when the cooling fan kicks in so I thought it might be the bearings in same. It happens so seldom I havent really looked checked the bearings. Is the locking up normal Jeff or is this from the bearings overheating ?
Mark-Please let me know if yours is better while towing if you would. Also did your old fan clutch have any play in it? Also did you go oem on the clutch
