1999 F150 5.4L 2wd surges when hot
My 1999 5.4l runs great then after driving about 20 minutes, surges & stalls if you try to accelerate. Then the idle surges from 600 to 1500 (back and forth). Connected a fuel pressure gauge, and it shows 30 then drops to near 0 then bounces back to 30 then near 0, then back to 30 etc. No codes are reporting. Any ideas what to check? Let it cool down, process repeats.
Has new fuel pump & filter.
Fuel pressure should never drop to zero and 30 psi is still too low.
The electric pump runs independent of the engine.
The only effect the engine has on pressure is on the regulator vacuum applied but cannot cut fuel off, only vary it over a 5 to 8 psi range if the regulator is good.
Better review the fuel system operation.
Good luck.
Good luck.
powerstroker100
03-19-2014 08:19 PM
Ev-95-F150
03-16-2014 08:02 PM
DJdemon6696
27
12-02-2007 04:43 PM
Tom Norman
04-14-2005 11:21 PM
