Do you put truck in Tow when hauling with EB??
#31
I have a 4,000 pound boat that I pull. With all my gear I guess I am at about 5,000 pounds. When pulling it is mostly highway. I have pulled with it on and with it off. Either way it pulls the load just fine BUT when going down steep hills in Tow a couple times the engine has downshifted really hard a couple times. Like freaked me out hard, RPMs shot way up. Is this normal? Is this okay for the truck? After that happened I finished my ride there and all the way home with the tow off and the truck did just fine. I have not noticed any difference in the MPGs I get with it on or off, I average about 9 - 10 pulling....sort of stopped paying too much attention to that, after all you don't pull a boat to the lake to not spend money on gas!
#32
#33
You want to use Tow/haul mode when ever you are towing. And yes it also helps with prolong the life of the transmission. Even though Ford does not say you have to use it but for those people that keep their trucks longer then 5 years is where using this helps. I know for GM it increases the line pressure which gives you that 'quicker' shift feel. Its because slippage=heat and the more heat in the transmission the worse it is. When you shift hard and fast, you actually prolong the life of the internal parts. I am sure in the Ford tranny it really is no different. Yes, in the 700r4 I wouldn't tow in 4th but in this ford I would as long as the road I am on is flat or relatively flat. If I was in a hilly area, I would remove 6th to minimize the gear hunting which is also not good for longevity.
here is some info on the ford tow/haul mode and its benefits in general.
http://www.intermotive.net/Tech%20Ti...ugust%2006.pdf
#34
the article above is rather dated, and is written for the transmissions of the time, mostly the 5r110.
here is ford's info for the 2011 tow/haul specifically for the 6r80 in the f150
2011 FORD F-150 TRANSMISSION FEATURES FASTER, SMOOTHER SHIFTING, BETTER FUEL ECONOMY | Ford Motor Company Newsroom
hubler13f
08-05-2012 01:50 PM
Rich K
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-15-2009 11:26 PM
Gearheadjo
04-29-2008 06:42 AM
