Connecticut Chapter Join Chapter, Leader:
Diesel mechanic shop near Danbury
Old 06-10-2013, 08:56 PM
Nickygunz's Avatar
Nickygunz
Nickygunz is offline
Picked up a 96 PSD and since the winter its been having starting issues. When it was cold it would not start at all. Once it got warmer if I spray a little starter fluid in the air filter it starts up and runs fine, but wont start without the starter fluid. I want to play around with it a bit to see if I can fix it, but if that fails can anyone recommend a good diesel shop near the Danbury area, I don't know much about diesel and generally hate going to mechanic, can't trust many of them. Thanks for the help.
Old 06-10-2013, 09:39 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
Stop with the starting fluid immediately before you ruin that engine.
Test to see if you have power to the large post on the drivers side of the glow plug relay.
The glow plug relay is the large relay just behind the fuel bowl to the left if you're standing in front of the truck looking into the engine bay.
Old 06-11-2013, 08:24 AM
Nickygunz's Avatar
Nickygunz
Originally Posted by 7.3 Rocket
Stop with the starting fluid immediately before you ruin that engine. .
Thanks for the suggestion, ill test the GPR.
I was hesitant to use the starter fluid but read through some forums and picked up one with upper cylinder lubricant and only gave it a quick 1 sec shot. I've only done this about 4 times since December.
Old 06-11-2013, 06:19 PM
7.3 Rocket's Avatar
7.3 Rocket
Wording in the original post made it sound like it was a daily thing.
I've seen 7.3s ruined by starting fluid and the compression #s aren't pretty. I'd be willing to bet the problem is glow plugs or glow plug relay. Most likely the relay.
Old 06-17-2013, 09:55 PM
Nickygunz's Avatar
Nickygunz
Finally got around to replacing the GPR but no luck, still no start. I am thinking its a fuel problem.
Anyone have any local CT shops they have taken thier PSD to, I want to get the truck back up and running this summer.
Old 06-18-2013, 04:53 PM
7.3 Rocket's Avatar
7.3 Rocket
Diesel shop, LLC in Preston does good work.
Dezl Newbie
28
01-05-2017 06:59 PM
n2o2h2arg
04-06-2012 11:10 AM
ajfetterman
11-19-2011 05:45 PM
xtrme34
13
11-14-2007 05:03 PM
truszip
01-02-2004 02:55 PM
Quick Reply: Diesel mechanic shop near Danbury
