Hey youins, it's June!
#121
Have Auto Zone order Timkin bearings. Larry has a point. The outer bearing is done, but the inner looks just fine. I've also put worse bearings back in and not had an issue. The outer bearing was just hot. I don't see any galling or pitting in the rollers. The temper in the steel is what I'm worried about. Your call.
I have some tinkering to do out in the shop today. I may get into the Chevelle again. I ran all the wires yesterday and cut everything to fit, but today I want to tape up the harness to protect it and keep it orderly.
-The Great
#123
well i didnt get nothing done today.. but thats all right .. alan on diesels with high compression (24-1) and high torque starters they use a rear brace and it really helps.. i have gone as far as putting arp-studs, grade 8 washers and self locking nuts on problem ones.. i have seen many stripped bolt holes and even some broken corner on blocks
#124
Dave. They didn't bend much. just enough to throw the nose cone over about .030. That doesn't sound like much, but it's enough to grind a flat spot in the ring gear. That big block wound up with a brace in the rear that pinched in between the block and the back of the starter so it absolutely could NOT swing away from the ring gear. I guess after I buy a new flexplate, I'll get some new bolts and make another bracket so this doesn't happen again.
#128
#129
#131
mornin guys,
well first day of bricks was a complete blast all the way up untill our 10th or 11th hole we took the mud truck through it had a lil bit more of a drop off than expected resulting in a busted tire rod wich ended our fun in the mud but didnt stop us from drivin around still i found some old fence and tied it up the best i could and it was somewhat drivable but atleast we got it home, headin back over today but just takin 4wheelers this time
#133
thats pretty much what happened to us but i couldnt find a bolt because that was my first thought on fixing it so i had to use some wire
#134
Hello all! Tried to catch up a little but it was hard!
Alan, live the new good deal impalla! Saw your Chevelle on the list....insert sad face here......
Rich, liked your pics from across the way. Glad your back safe.
Ok Big Red got seat belts installed and such. Didn't get the steering worked on yet, but its manageable but can't make tight right hand turns.
Hope everyone is doing well! I've been working tons of overtime and being the head honcho is not as much fun as SGT was. LT. Is too much paperwork! Lol
