Radiator Transmission Connection Leak
I just changed out my radiator and thermostat on my 1990 Ford Aerostar, 4.0L and mostly the job went very well. Just one question area:
1. Where the Transmission Lines go into the radiator they use a brass connector. The radiator box said not to tighten the brass connectors tighter than 10lbs torque. I did so. But both are slightly leaking tran fluid. Not a lot. I took them off and cleaned them and put them back in and same results. I seem to remember something about brass connectors will expand from the heat and probably seal in a short time. Any thoughts on this or how to correct?
Thanks,
John
Thanks,
John
Meatball98
02-24-2015 09:23 PM
bottomacher
Ford Truck Parts for Sale
07-09-2014 05:54 PM
SamCNY
1997-2006 Expedition & Navigator
13
01-08-2014 10:06 AM
Jeff and Nicolle
01-07-2014 02:20 PM
LARIAT 85
07-10-2013 09:38 AM
1998, coming, connection, connections, expedition, f250, fix, ford, leak, leaking, lines, radiator, tape, trans, transmission
