wiring questions
wiring questions
I am planning to restore and install new original taillights on my flareside F100. The truck currently has LED taillights recessed into the rear pan. If I splice into the correct wires and connect them to the new taillights - but leave the LED's hooked up- will this make a problem with the amp draw or the fuse? I like the brightness for braking, however it looks (to me) bad without the old ford taillights.
thanks for the info - can I call u Rusty- My concern was that perhaps the previous owner may have changed the system since the LED's require so few amps less, and I may be blowing new turn flashers etc. I'm not even aware of. As you see , I'm no mechanic/electrician and appreciate those here who give so freely years of experience
I hooked it up and it works fine. I like the look of those old "emblem" lights on the flareside.
Thanks again
Thanks again
g-money-55
24
06-07-2019 02:00 PM
BTclassics
Electrical Systems/Wiring
56
05-09-2017 09:51 PM
briansrapier
04-14-2006 01:13 AM
crombach
09-04-2001 01:30 AM
