Need help with dimensions of a cab-over camper for my 1959 f100.
Old 04-28-2015, 03:03 PM
Justo707's Avatar
Justo707
Justo707 is offline
Been searching for a cab-over camper for my 1959 f100 styleside, I've found a couple in my area for a good price but I'm not quite sure if they would fit. I believe it's a 8 foot bed. But I'm not sure if it would fit between the wheel wells in the bed. I've never dealt with cab-over campers before so I'm pretty skeptical about what I should get, or if i can even put one on my truck. Any information would be greatly appreciated, thank you
Old 04-30-2015, 03:37 PM
capterik's Avatar
capterik
capterik is offline
Well, generally the issue isn't the fit between the wheel wells, unless yours isn't stock, the question is height of the over cab area, and wether you have clearance, you can always make a platform to raise the camper if necessary. Biggest issue may be the weight of the camper, its only an F100, some of those campers are mighty heavy that fit an 8ft bed, your best bet would be a pop up style. Take measurements of your truck dimensions, length of bed, width between wheel wells, height from bed floor to top of cab, and then when you go look at them, compare measurements. Good luck.
gogreenwave
1983 - 2012 Ranger & B-Series
02-06-2012 06:00 PM
Dirtfarmer69
1999 to 2016 Super Duty
06-23-2009 01:18 AM
snortf100
10-21-2007 10:18 AM
fatdaddy
12-24-2001 06:19 AM
Quick Reply: Need help with dimensions of a cab-over camper for my 1959 f100.
