1949 F4 Flatbed
1949 F4 Flatbed
New to forum with new project. I have a 1949 Ford F4 flatbed with 158" wheelbase and a 12' bed. Truck assembled in, Kansas City.
The bed construction seems to be unique although I have seen one other photo that resembles it. any comments will be appreciated.
As for the rest of the truck, I have it completely disassembled, sourcing a few needed parts. It has a Flathead 226 6cyl H.
As the build progresses I will update.
My welcome too. Love the big models. But must say, if you have a 158" wheelbase the truck has either been lengthened from its stock 134" wheelbase, or it's really an F-5 or F-6. F-4s all had 134" wheelbase single wall frames. You might check the VIN to confirm, or crawl under it to see if there are signs of the frame having been stretched. Also would suggest you become familiar with your "widow maker" wheels. Stu
It is an F4 with a 24" splice. It appears to have been done in the factory, very clean welds, section fits in with matching angles, reinforcing plate cut clean and angles along frame, bolts on with consistant hole pattern. Also has additional cross member at this location. there is a section added on the back also very clean in matching the frame. Frame will be back from powdercoat later this week.
I have already sourced a set of seven 19.5" wheels, these will be in the shop tomorrow.
I am restoring this truck back to how I received it including the bed. I will probably embilish the interior upholstry, but that is it.
tiim5
23
08-30-2015 06:38 AM
jrmwilson
06-23-2012 01:05 AM
kld1958
06-23-2007 08:30 PM
