Newbe looking for info on jag swap
Hi everyone, been reading old threads about 49 f1 trucks and finally joined site. I'm looking forward to sharing info about our builds. My truck is a 49 and I've purchased a 83 xj6. Truck is in many pieces with a bare frame. I guess I'll have to put back together to determine tire location(apart when I bought). RTR
Just purchased mig welder and have installed cab corners. Plans are get cab ready then suspension,sbf, not sure about soft mount or weld ifs. I'll prob tack then get a pro for final weld. Jag IRS, tank under bed. Been seeing older builds, hopefully get more info on suspension,steering,brakes ect now that I'm a member. Thanks for invite,I've read about your threads and others, but they were old threads
Use the "search forum" feature in the tool bar toward the top of the forum to find build threads.
I've got an 84 XJ6 front end I pulled from a donor car last summer (bought the stupid thing years ago, but it just sat). The plan is to do the swap next summer (just won't fit in this coming summer's schedule). I've been waiting to get around to this for forever, but I'll be excited to see your build, and/or contribute to the knowledge pool if you're still working toward your swap by the time I get around to mine.
Welcome to FTE!
Jim
Welcome to FTE!
Jim
Here is another build thread for the Jag IFS.
Ford Truck Enthusiasts Forums - 48 Steel's Album: 1948 Ford F1 Kustom
_____________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
I'm also using a jag ifs on an F1. Have some basic pics in my gallery. 49 Willard and I were discussing ride height on another thread. I recently replaced my springs with new, oe springs and my ride height is too high now. The frame at the front bumper used to measure 9 to 9 1/2 at the bottom of the frame. Now its at 13". The old setup was stock springs, all four shims removed, one washer between the control arm and spring plate. I was getting some mild rubbing of the tires on the inside top fender lip on big bumps. With the new springs, all the shims and one washer it's at the 13", too high. The new springs are stiffer than the old, the wire diameter is .020 thicker. I want to keep the ride height at about 11", which still looks good, but should solve my rubbing problem. I'm going to remove the springs, and remove the four shims. That will reduce spring preload by 1/2", lowering the truck by 1 to 1 1/2". I can always add washers between the control arm and plate to fine tune. When I'm happy, I'll post results.
Hey Rusty,
We used a spring spacer on the driver's side of our 1950 to stop the tire rubbing. It's a bit of a stop gap but it does work & you just forget about it after a while. We are going to get some replacement coil springs made as the longterm replacement. (We also just bailed & bought smaller diameter tires up front).
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Thanks again everyone. My build will be slow. I'll have to get off I phone and print some build threads for my build and to show people that I may have to use for helping me with ifs IRS. Are there measurement I can use for ifs without mocking up cab and fenders. My frame is bare
I suggest reading my MIG welding tutorial:
https://www.ford-trucks.com/forums/1...-practice.html
Get about 6' of 2 or 3" wide 1/8" thick strap steel. Cut it into 6" lengths and practice running beads for a weekend or a few evenings. Just run simple beads on the metal, 2 or 3 beads per piece until you can consistantly run nice even straight 1/4" wide beads with correct penetration and profile. Then butt two pieces together, tack and weld them, following my instructions. By the time you weld ~ 20 pieces together your welds should be looking quite good. Next switch to 16 ga sheet and do the same. Ask an experienced welder to look over you practice pieces, but you should be about ready to take on any welding task. If you have any questions, feel free to drop me an email or PM (click on my user name in any of my posts and a menu will drop down.).
