A couple of quick questions
Old 05-02-2013, 09:02 PM
AlanMac's Avatar
AlanMac
AlanMac is offline
1986 F250, 460 cu.in., 2WD
Just a couple of questions about the old truck...
Is the dome light supposed to come on when the door opens? It works when you reach up and turn it on manually.
http://i437.photobucket.com/albums/qq93/mcclintick_2008/Dome%20Light/domelight.jpg
The metal tubing connected to the power steering pump swings forward and backward. The nut is tight. Is there some practical reason for this or is it supposed to be stationary when tight?
http://i437.photobucket.com/albums/qq93/mcclintick_2008/PS%20pump/PSpumpconnectionup.jpg
http://i437.photobucket.com/albums/qq93/mcclintick_2008/PS%20pump/PSpumpconnectiondown.jpg
Old 05-02-2013, 10:10 PM
JayzDaddy's Avatar
JayzDaddy
JayzDaddy is offline
To answer #1 yes the middle light is supposed to come on when the door opens. If it does not
1 no power x wrong you can cut the map lights on you say
2 center "dome" bulb is blown~ possible, replace if bad
3 door switch is stuck or bad~ possible, manually work your switch, spray around push button with dielectic spray
Old 05-02-2013, 10:14 PM
JayzDaddy's Avatar
JayzDaddy
To answer #2
I dont know for sure but mine do not move easily. I dare not put more pressure on mine as i am a hulking clutz and am afraid of bending, kinking, or breaking something. In dealing with a compression type fitthing over the years it should not move without a good bit of force. Doesnt seem quite right.
Old 05-02-2013, 10:17 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
It doesn't surprise me that they move, they have O rings and are designed to be able to move to accommodate engine movement and to transmit less vibration.
randella
11-12-2015 08:34 PM
MSP-F250
04-18-2015 04:13 PM
jerrycmorrow
1983 - 2012 Ranger & B-Series
06-06-2013 12:50 PM
amer28
03-03-2012 07:58 AM
cworley250sd
1999 to 2016 Super Duty
13
02-05-2010 02:10 PM
Quick Reply: A couple of quick questions
