Not great.....may have a random rogue vacuum leak that i can't find making my A/C go thru the defrost instead of vent
-The Great
could be the baffle itself.. sometimes the actuators go bad and fail to work... course have noticed in my truck it gets confused at times too... usually playing with the switch solves it...
Rick he has the v10 so no vacuum pump. Could be an issue with the blend door arm coming off of the actuator under the dash. That is a common thing on the F150.
