steering issues
steering issues
i have a 94 f150 reg cab long bed 300 6 5 speed with 209000 on er ibwas driving the other day about 35 mph and all of the sudden it yanked to the left and once i pulled it back it didnt do it again for bout a mile or so and it did it to the right so i drained some fluid and added a lil lucas power steerin additive and has only done it 2 times in the last 3 days or so any ideas ? i was told it was the spool valve sticking in the pump and just a lil more info truck has f250 leafs in the rear and a 3 inch lift in the front running 31x10.50x15 i was thinking of just slammin a new pump in it to see what happens
If its jerking direction I doubt you have a pump issue check your steering components. For what it is worth I personally would never put another C-II back on mine went with changing fluid due to it getting dark and smelling fine getting it all out of the box did it again, and finally pump started doing the normal whine and slow response.
Solution for that E series vans had saginaw pumps swap bracket and all and enjoy. But first check your steering components first make sure everything is good and tight sounds to me like something is wore out.
Curtis
Curtis
its not jerking just wheel turns buy itself lol kinda weird but thats what its doin i check all my steering components everything is tight and actually it was all replaced less than 4 months ago when it suddenly turns by itself u hear the pump whine like crazy and it only does it for a second or so then goes away im running to stock original pump and the fluid was black and smelled like burnt tranny fluid so i did the flush on it at work which is at a valvoline and then i drained it down some and put that lucas in does it less often thats y i thought it may have bern the pump it has 209000 miles on it and thanks for the reply
clem1226
23
10-19-2011 10:09 AM
Duke78
01-19-2010 06:34 PM
Madsan
10-04-2009 10:22 PM
gingerbreadmaniac
05-11-2004 08:58 PM
