1995 4.9 Got Spark... No Fuel
Old 05-25-2013, 10:07 AM
teched's Avatar
teched
teched is offline
Hello all, Truck has 224,000 miles on her and ran great on Thursday. I went to fire it up Friday night and it cranked a couple of times, fired and then died. I cranked and cranked but no fire. I went out this morning and checked the spark, Looks good, Plugs are dry. Is there any way I can check for fuel closer to the injectors? I know some vehicles had a what looked to be an tire air valve stem, that you hooked up a meter to measure fuel pressure. The fuel pump looks to be relatively new and I put a new fuel filter in it last year. Not because it was plugged, but it had rusted and was leaking. I can here the fuel pump come on. I even dumped a couple of gallons of gas in it just in case it was not picking it up.
Old 05-25-2013, 11:30 AM
Gembone's Avatar
Gembone
Gembone is offline
Fuel rail should have a check valve. push in the stem and fuel should come out if you are getting fuel to the rail.
Is the vehicle a 95 or is this an implant into an older vehicle?
What kind of pump and fuel pickup are you using?
Old 05-25-2013, 12:28 PM
teched's Avatar
teched
teched is offline
It is all stock and original 1995. I will check the fuel rail again
Old 05-25-2013, 12:42 PM
teched's Avatar
teched
teched is offline
I was able to find the valve and I am getting gas to the rail. Is there a fuse or relay that send power to the injectors?
Old 05-25-2013, 02:33 PM
Gembone's Avatar
Gembone
Gembone is offline
do you have a set of noid lights? they can be used to check for injector pulse from the computer control.
they plug into the wire at the injector.
Old 05-26-2013, 07:17 AM
teched's Avatar
teched
teched is offline
I got her runnin!!! Thanks Gembone for the help. I must have flooded it badly. When I checked for spark I removed the front plug(easiest to get to) and it was dry and had good spark. So I assumed that all the rest were OK. I ended up spraying a whole can of ether into it and getting it to run on the ether. It still would not stay running so I went in the house to do some more research and someone suggested the inertia switch. I checked it and it was OK. I tried the ignition again and it fired on one cylinder. I then just kept cranking and slowly it picked up another and another and finally she was running. Thanks again. Sometimes the stupid thing get ya!
beersy50
48
11-13-2010 04:51 PM
Rod Bender
29
10-24-2009 08:10 PM
skookum
Aerostar
15
09-11-2009 04:12 PM
fisher1995
06-08-2007 08:25 AM
Diamond Jim
11-12-2006 06:49 PM
Quick Reply: 1995 4.9 Got Spark... No Fuel
