planning a lift wondering about options for radius arms
Old 04-23-2013, 11:52 AM
HD991994F150's Avatar
HD991994F150
HD991994F150 is offline
I want to do a four inch lift on my truck. Wondering if it is cheaper to buy a kit with arms or buy one without and buy them on there own or if at 4 inchs i should use the drop brackets and buy new factory radius arms any advice?
Old 04-23-2013, 01:55 PM
blue924.9's Avatar
blue924.9
blue924.9 is offline
i would just get ones with a kit with everything else. then all the other components are made to work with each other
Old 04-23-2013, 06:37 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Extended radius arms will increase your wheel travel to take advantage of your lift. They'll also help keep your caster near the factory recommendation.
Seems that most of the extended radius arms are at least $500 new (unless you can find a good used pair). Most decent lift kits are about $1k including the radius arms.
I'd recommend getting the arms with a kit.
Old 04-23-2013, 06:49 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
If you really want to do a lift, buy a full lift system. It will give you everything you need. All the parts will be meant to work with each other.
motor-man
1999 to 2016 Super Duty
12-17-2012 05:16 PM
Brettboat
11-07-2012 09:34 PM
|WYG|SS
Offroad & 4x4
01-21-2011 10:21 PM
newfordman
02-22-2010 01:15 PM
cjbronco
1978 - 1996 Big Bronco
10-25-2005 12:44 PM
Quick Reply: planning a lift wondering about options for radius arms
