85 6.9 slow cranking, acting like dead batteries
Old 04-22-2013, 02:34 PM
surfaccing's Avatar
surfaccing
surfaccing is offline
so I replaced the battery cables with 2/0 gauge welding wire soldered and heat shrinked with new ground wires. hook up 2 yellow top optima's and still slow crank, so I drop the batteries in my 6.0 start it up and run 2 jumper cables to the new battery cables and start the 6.0 and it still cranks slow! I cant figure it out? any ideas? was running a month ago I just and I suppose the cables went bad after almost 30years so this is why I made new ones
Old 04-22-2013, 02:56 PM
genscripter's Avatar
genscripter
genscripter is offline
I still don't get why you changed the cables?
Old 04-22-2013, 03:26 PM
Fordidipower's Avatar
Fordidipower
Fordidipower is offline
Next would be to get the starter tested at an auto parts store.
Old 04-22-2013, 03:43 PM
surfaccing's Avatar
surfaccing
I tested the starter and I pulled a starter out of my 84 6.9 which had a rebuild about a year ago and I know its good and still nothing chwcked power at my starter switch and I found a bad connection fixed that and then batteries straight to the new cables. glad to say I got it working! just checked ever little wire and working on putting all brand new wires into this girl.
my old cables where shot rotted out from the inside so new cables and I wanted it to carry larger amp load and bigger batteries which is why I went 2/0 gauge cables
Old 04-22-2013, 06:47 PM
genscripter
I've read your post 3 times, I still can't read what you are writing.
I get your cables were "rotted" but that's not a reason to replace them unless you just felt the urge to do it. I'm not following what you want us to help you with?
Did you have the same starting problem before you replaced the cables? What is the voltage at the batteries with the engine off? what is the voltage while idling? How new is your alternator? When was the last time you changed your voltage regulator? You might have ruled out the starter, but a year could be long enough for it to start going bad (but i don't think it's the starter)
Old 04-22-2013, 08:46 PM
NorthernDiesel's Avatar
NorthernDiesel
NorthernDiesel is offline
I had some issues with the starter a while back, and it turned out to be bad connection between the starter and the block. I cleaned and smoothed the face of the starter and reattached it, and it improved greatly. There was alot of crud in there and since that's the ground path for it, it was reducing the current it could pass.
I don't remember exactly, but I may have removed the back half of the starter and cleaned bewteen the segments of the case as well (again, the case is the ground path)
Donno if that's your problem but it could help.
El Campo
1999 to 2016 Super Duty
08-03-2015 10:24 PM
jmgekeler
16
09-20-2010 09:09 PM
llee
01-29-2009 03:36 PM
754x4fordman
02-24-2004 09:42 AM
buckford
02-01-2004 12:43 PM
Quick Reply: 85 6.9 slow cranking, acting like dead batteries
