Headlights won't turn on
I just purchased a 98 Expedition from a friend. He told me that both headlights were not working and that there was a blown fuse that needed replacing. i've checked the fuses and they're fine. I replced the bulbs, still nothing. Is there a headlight relay that I could check, does anyone know where it is? Any suggestions? Help. Please.
Hi Adam and welcome to FTE
There is one fuse under the hood and 3 under the dash for the headlights. There are no relays for them.
Next step would probably be to check for power coming out of the headlight switch on the red/yellow wire. If that is good then the next likely candidate would be the multifunction (signal, high beam etc) switch.
Here is what the fine manual says.......
Removal
Disconnect the battery ground cable
Turn the headlamp switch **** to the headlamp position and pull the ****.
Insert a thin tool to release the headlamp switch **** and remove. (There is a small cut out in the bottom of the ****. You can use a thin screwdriver or pick to press the tab)
Turn the headlamp switch **** 180 degrees and install. (Just put the **** back on upside down)
Turn counterclockwise until the back of the headlamp switch **** is in the OFF position.
Turn the headlamp switch **** fully clockwise.
Remove the headlamp switch. (just pull it straight out)
Pull the headlamp switch from the instrument panel.
Disconnect the electrical connectors.
Installation
NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
To install, reverse the removal procedure.
Removal
Installation
To get at the multifunction switch you need to remove the upper and lower steering column covers.....just a few screws.
Check for power coming from the headlight switch on the R/Y wire and then from the switch to the lights on the R/Bk (low beam) and Gy/O (high beam) wires.
Hey guys, my Expedition had the same problem. I was searching the net, found your postings, and checked both the headlight switch and the multi-function switch and it turned out to be the multi-function. Easy replacement! Saved a bunch from taking it to the dealer! Thanks you guys.....joined the forum because of it! Next...steering stabilizer installation! Great people and ideas!
Open the hood and look for two black metal tabs with "L" shaped ends that are positioned above each headlight. The tabs have to be lifted up about 2 " to release the headlights. If I recall correctly, the tabs have to be tipped back slightly while lifted to release their built in locking mechanism. Once the tabs are up, the light housing can be slid forward and removed. Bear in mind that the wiring is still attached at this point. Removing the bulb is not hard, just unscrewing a collar holding the bulb assembly to the headlight unit. The new bulb must be ultra-clean, free from all contaminants, including skin oil from your fingertips. Have a little rubbing alcohol and a lint-free rag around to rinse the bulb just before reinstallation.
How to replace multifunction switch on 1999 Lincoln Navigator. Headlights won't turn o
