Very puzzling problem. Honk the horn, and the engine dies.
If I honk the horn, the truck immediately shuts off as if I turned the key off. Will strart right back up, but does it every time.
Second thing. When the temp. is below 60°F. the truck will start right up, but as soon as I give any gas pedal at all, it shuts off as if I turned of the key. The truck will start back up, and idle fine. I can put in gear, and the truck will roll, but if I give any pedal at all, she dies.
If I keep doing this, eventually, I can get a little bit of speed and give a tiny bit of gas and keep going. After about a mile or two, I can increase the amount of gas and she wil occasionally miss like wanting to die, but catches and keeps going.
Does not do this above about 60° outside temp.
I'm not sure if the two scenarios are related, but am wondering how the temperature can shut off fuel???
1997 F250 with 240k miles. I have changed out the fuel filter with no effect.
Please, anyone have any ideas?
Did yo
piperpilot
08-17-2019 10:36 AM
thecrock0984
08-08-2010 10:25 AM
