Why is it impossible to fill my truck with fuel???
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> Does anyone else have issues with filling their truck (with side tanks) and the pump constantly stopping, fuel coming up and washing side of truck, pumping fuel real slow? It was driving me crazy; I am so use to the set up the pump and let it fill ‘mode’.
My 1976 has the big fill tubes I am guessing from the leaded days but I wondered of the bends in the metal portion of the fill tube are curved in such a way to make my gas station trips suck? Another issue is I can’t even push the fuel nozzle in all the way as that has a curve also!
There has got to be some sort of method here…????
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
My '79 (smaller filler opening for unleaded) developed this problem out of nowhere several years ago. I dropped the tank and found absolutely no obstruction or kinks in neither the filler nor vent hoses. Reinstalling the tank with a new set of hoses cured about 80% of the problem. Clamping the two together (similar to how they came taped at the factor) cured the issue completely. I never truly understood what happened.
Also helps to park with the filler on the uphill side if there is a slope at the station.
Then just fool around till you find the right angle. Mine is usually with the handle toward the front of the truck.
Some of the guys have used zip ties to round out the filler after removing the metal frame guard. However one must be careful. There's a reason that guard is there.
Also some pump handles fit better than others. If you find such a place, take note.
I'm planning on surgery on my frame when I take my bed off.
Until then, it's the gift that keeps on giving.
You should check the large rubber hose that connects the fill pipe to the tank. That hose pinches down pretty close where it passes between the bottom of the bed and the frame. If it got pinched too tight it would'nt let gas flow into the tank backing up out the fill pipe. My truck, a 77 has a seperate smaller hose maybe 3/4 inch? to help vent air out of the tank when filling. Not sure if yours has that hose. These California gas pumps can be hard to use though.
Our trucks may be part of the problem but not all of it. My brother was a manager of a large gas station for about 30 years and he said it has to do with the nozzles they have to use now. They are not made like the old ones were and trip off more easy . I had some 79s a few years back and never had much problem but my 73 is real hard to fill . I don't let it fill unless i am holding the handle to control the speed. Accept when i travel through Oregon, not allowed to fill your own car there , attendants only.
It would if your state Government changed it the way Oregon did. It was not the fuel station owners that did it but they may have helped make it State law. I live just out of Oregon , 2 miles inside Idaho , so i don't buy fuel there accept when I have to cross their state to get to Washington. Then I have to fuel up 1 time each way.
Wow, thanks for the replies...glad I am not the only one that has to deal with this although I wish none of us did. I was at a BP station down the street from me; they are a little newer but I am not sure on the nozzle; although something newer that would have something to do with cleaning up vapors or that the EPA had their hand in would explain the problem. I got some good ideas, I will try the upside down thing as well as another gas station all together. I also have to drop the aft tank to replace the sending unit and I will look at replacing the rubber lines...and try to zip tie to change their shape. Clamping together...although that seems strange I will do it - especially if it fixed the problem! My truck is from California...after seeing all the differences in gas lines, emissions, tank configurations....and freakin gas caps; I don't think I understand anything anymore.
As long as you're going to be replacing the rubber lines, be sure you at least send some air down thhe hard ones to clean any mobile gunk out. Gets pretty nasty in there after this long.
And clean your tank since its coming out. The old pickup filters break apart and float around in there.
Have fun.
Have fun.
That's a good idea...I will do that with compressed air.
Just slosh some gasoline around and empty to clean tank?
Wish I did this on a 72 Fury I had that broke down on the way to California...years back when I thought I could replace the leaking tank with one from a junkyard and not clean anything! Dumb!
