Ford wire terminals
Ford wire terminals
I am looking for some Ford wire terminals I can use to clean up some wiring. I need 3 different types:
EEC-IV - I'm about 99% sure that the wedgelock, 0.110, 18-20 ga. terminal will work and it looks like some companies are producing this
MASS Air sensor connector (4 wire, oval style)- Does anyone know what these are called or the size that will fit in the connector? I haven't been able to get much info on this.
PDU Relays - I am looking for the type of connector where the relays in the power distribution unit fit into. I have an empty space for a relay and I'd like to use it. Have any details of these?
If I can get some additional info about the second two, I wanted to see if I could find them a little cheaper on an electronics site rather than a Ford site where they are more expensive.
Any help is appreciated.
RJM Injection Tech — Ford Terminals
RJM Injection Tech — Mass Air Flow 1989-1995
Perhaps one of these may work for your relay project: RJM Injection Tech — relay
I've seen the Ford EEC-IV terminals and I don't feel like paying a half-dollar each.
The second link to the MASS Air connector is correct, I need the terminals inside (but I might be able to get by without them).
And maybe the Small Relay & 3G stator Terminal may work but they are all sold out.
That's why I was trying to find alternatives. The thing about rjminjection is they don't give part numbers because they know the prices are too high if someone finds them elsewhere.
The MAF connector is also a Standard Motor Products Part No. S-658. Rock Auto carries them for ~11$
Ajtipler
55
01-18-2019 08:17 AM
reamer
04-04-2014 05:24 PM
