Air Raid - 2005 6.o Filter
Old 03-20-2013, 01:06 PM
adbscu's Avatar
adbscu
adbscu is offline
Hi,
I have a 05 with an Air Raid filter (got the truck used with it in 08): should I order a new filter (http://www.airaid.com/kit_replacement.aspx)? or just cleaned (did it already a few times..now it's really dirty).
If i go the replacement route (part number 400-131-1) should i go with the SynthaFlow or Syntha Max?
The truck is used for towing (on a weekend basis), we do go down some pretty dusty roads at times.
Old 03-23-2013, 06:48 AM
edawgm's Avatar
edawgm
edawgm is offline
Old 04-01-2013, 11:58 PM
caveman's Avatar
caveman
caveman is offline
If you clean it good with the cleaner kit and re oil it should be good. I had mine new in 05 and ran it for 6 years and it was great. I clean it often and was always on dusty Forrest service roads I disagree with the keep it stock fan boys. Each to their own though.
Old 07-08-2013, 04:31 AM
lariat97's Avatar
lariat97
lariat97 is offline
The stock Donaldson unit on the 6.0s can feed a 500 hp motor. It is super good at catching dirt. I would never go to a aftermarket filter on my 6.0.
Old 08-06-2013, 01:39 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,100 Likes on 1,000 Posts
Check the blades of your turbo and I believe you would then return to a stock air induction system......
If you are determined to continue using what you have, go with a NEW filter.
RoyWalker
1999 to 2016 Super Duty
19
12-26-2015 09:45 AM
adbscu
03-22-2013 12:48 PM
templar514
03-07-2009 06:08 PM
rhodeisland350
10-16-2008 09:48 PM
cowboysmikek
02-16-2005 09:08 PM
Quick Reply: Air Raid - 2005 6.o Filter
