lift question
lift question
What would be a good lift height for a 92 f350 crew cab long box single rear axle to keep it still driveable on the interstate but a little taller? should I go suspension or body lift? I don't want to go crazy with it and I still want it to pull trailers good just want to bring it up a bit and put larger tires for more clearance. It has the 351w in it with a 5 speed. I was thinking like 3in or so and I don't want to spend a mint on it either.
I think my suspension is in good shape. Dont realy know how to check it but it rides pretty good and stands good. It has 150k miles on it. Thats not a bad idea I would have to put flairs on it to keep crap from flying up but I think they look good with fender flairs anyway. Dang wheels and tires are pricey lol. But if I did that I could keep my stock wheels and tires for long trips and whatnot. How much higher would that take it up?
It all depends where you are at. If you still have stock 29's, and go to 35's, well your truck physically lift 3 inches due to the six inch overall height increase of the tire. Check out treadwright tires if your in the states, very affordable and I have heard good things. Also check out fierce MT's if that's the look you want. They are made by goodyear if I recall
Ahh makes sense, I'm in alberta so you need 35's plus just go do a little playing. The guys who build dedicated offroad rigs run 40 swampers as a base line, its soft and thick with holes that will swallow most trucks whole. Mind I think yours or mine would act more like a boat with all that underside surface area.
Stock, you should have 235/85R16. Not 29" like c_root was trying to say. You SHOULD be able to fit 315/75R16 (close to 35"x12.5"). 305/75R16 is a 33"x12.5" tire also. You will probably have to trim or shim the bumper. You would also need rims that are 16" by 10" wide with a 4"-4.5" backspacing. The less backspacing the better. Be sure that whatever rims you find are able to support a load.
I would avoid lifting it if you want to pull trailers and stuff still. You will probably want to regear your axles to 4.56 so you can still turn the wheels without too much struggle.
Adds a leaf spring to the pack to bring the front end up a few inches. If you're into the leveled look, it won't hurt anything. But the truck won't sit level with a heavy trailer on it. You may not have to mess with the bumper with bigger tires if you use a leveling kit. I'm unsure though.
