Sirius antenna relocation question
Old 03-26-2013, 10:00 PM
Ridin'High's Avatar
Ridin'High
Ridin'High is offline
I need to relocate my Sirius antenna because I'll be putting a camper on my SD this summer. I hope someone here can help.
I located what looks like a FAKRA connection under the dash, just below the instrument cluster. I assume the wire at the bottom comes from the radio, and the wire at the top comes from the antenna.
Does anyone here know if the antenna adapter shown below will plug into the OEM connector?
Thanks,
Gary
Old 03-28-2013, 05:07 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Check this thread (and other useful links within it), might have some answers for you.
https://www.ford-trucks.com/forums/1...-relocate.html
Old 03-30-2013, 04:39 PM
Hessdawg's Avatar
Hessdawg
Hessdawg is offline
Looks like you should be able connect with that adapter
Or you might be able to pop out sat connector and plug it right in
Old 03-30-2013, 05:44 PM
Ridin'High's Avatar
Ridin'High
Thanks, Matt and Hessdawg, I went ahead and ordered the antenna with adapter. It's only $23.00 shipped so I think it's worth a try.
Ordered the antenna here: TERK XMicro XM Radio Micro Antenna XMICRO | Pink FAKRA Single Lead Adapter
I'll post the results when I get a chance to try it out.
Old 10-09-2013, 11:33 PM
700ccg13's Avatar
700ccg13
700ccg13 is offline
Hi all. Any chance yall know if that fakra connector is located under the dash in the 2013 f150? Ive been trying to relocate my antenna but cant find a good way. The fakra doesnt go up to the unit. I dont know how its hooked to the unit.
Any info helps!! Thanks
Old 10-10-2013, 07:55 AM
Ridin'High's Avatar
Ridin'High
Sorry i never posted about my results with the new antenna. It worked out just fine. I can't speak to the location of the fakra connector in the F150, but if you find it, the antenna I used (see link in my previous post) should work for you too. I ran the wire through the firewall and out onto the hood.
PapaBearYuma
04-10-2017 01:19 PM
thatguy71
13
09-17-2015 10:40 PM
willie1227
2004 - 2008 F150
16
01-25-2009 02:23 PM
Adirondacker
16
06-01-2008 12:58 PM
Octane
09-17-2007 02:48 PM
Quick Reply: Sirius antenna relocation question
