Lighting upgrades?
#47
#48
#49
Get some headlight relays they will do 2 good things. They will provide more power to the bulbs and take the load off of the headlight switch.
Ditch the tinted Silverstars. They are just marketing hype. Go with a good clear bulb like Sylvania Xtravision or GE Nighthawk or maybe something from Phillips.
I have the Hella 550 fog lights mounted in the PSD bumper. My 95 XLT came with the impact strip bumper, so do most I have seen. I think its the cleanest option for mounting a pair of lights.
I have new FoMoCo headlights in mine, they are the best. TYC makes the best aftermarket reproduction headlights I have come across. The Keystone ones are about as good. The others don't even come close to fitting right and have poor beam patterns.
#50
Ford parts describe the bumper with holes as the diesel bumper, here the bumper moldings show a different part number from the solid bumper.
Bumper, Front, Diesel, with Air hole, 92-97
(Ford) F3TZ-17757-AB
Bumper Strip, Front Center, Diesel, 92-97
(Ford) F3TZ-17K833-K
Bumper Strip, Front Outer Left, Diesel, 92-97
(Ford) F3TZ-17K833-J
Bumper Strip, Front Outer Right, Diesel, 92-97
(Ford) F3TZ-17K833-H
I dont know where you came up with those part numbers, but they are wrong. The "hole" bumper did not come out till 94.
#51
on
Accelerator Pedal Assembly - See "Throttle Assembly"
APCM (Auxiliary Idle Controller)
(Ford) F5PZ-12B641-AA
(Ford) F5TF-12B641-AD with LCD display
APCM (Auxilliary Idle Controller) wiring harness
(Ford) XC3Z-14A411-AA
Air Dam
(Ford) F2TZ17626A
(Ford) F2TZ17626B
(Ford) F3TZ17626B (Fiberglass for Ford Lightning)
AC Delete Idler Pulley
(Ford) F5TE 19A216 AB F5TZ 8678 AC
(Motorcraft) YS-261
ACT Air Charge Temp Sensor
(Ford) F5AZ-12A697A (Plastic, in air filter housing)
(Ford) F3VY-12A647-A (Metal, in air filter housing)
Air Cleaner Housing Cover 94-97 F-series (Updated Cover)
(Ford) F6TZ-9661-AB
Air Cleaner Housing Nuts 94-97 F-series (Updated Spring Loaded Steel Nuts)
(Ford) F7TZ-9B680-AA
Air Filter, Open Element (Tymar, Etc)
(Baldwin) PA2818
(Donaldson) B085011
(Fleetguard) AH1141
Air Filter Gauge
(Ford) F7TZ-9N622-AA
Alternator
(Ford) F5UU-10300-CA (215Amp Ambulance alternator)
(Motorcraft) GL504RM 130A standard item (95)
(Motorcraft) GL500RM 110A (130A?) standard item (96-97)
Alternator Pully
(Ford) F5UZ-10344-C (8 rib mid 95 and newer)
Antifoaming Additive (counters RTV reaction with oil)
(Fleetrite) CH1824392
(Lubrizol) 888
Auto Hub Lock Grease
(Ford) E1TZ-19590-A
Auto Hub Nut Assembly
(Ford) F6TZ-3N105-BB (retainer nut, retainer key, 3 washers)
Battery Cable, Positive
(Interstate) 2114-001
Battery Cable, Negative, Passenger side
(Ford) F5TZ-14301-A
Bed Mount Insulators/Bushings 6 needed
(Ford) E9TZ-5C036-A
Belt - See Serpentine Belt
Block Heater w/o Cord
(Ford) F4TZ-6A051-A
Block Heater Cord
(Ford) F4TZ-6B018-B
Brake booster ZERO LOSS
(Ford) F5TZ-2005-CA
Brake dust shield '94 (may fit earlier years) left...... Ford
(Ford) F2TZ-2K005-A (left)
(Ford) F2TZ-2K004-A (right)
Brake Master Cylinder Sensor (at the end of MC)
(Ford) F3TZ-9F924-BB (original)
(Ford) 1L1Z-9G652-AA (replacement for recalled switches)
Brake Pads
(Bendix) MDK655FM (fleet grade)
(Ford) XU2Z-2V001-ASA (Autolite with hardware)
(Performance Friction) 0655.10 (96-97)
Brake Shoes
(Bendix) AF583 (semi-metallic)
Bushings
(Energy Suspension) 4-7110 (radius arm; polyurethane 93-98 2WD F250-F350)
(Energy Suspension) 4-5106 (front sway arm; polyurethane)
(Energy Suspension) 4-5104 (rear sway arm; polyurethane)
(Energy Suspension) 4-4107 (Body mount bushings, 1980-1996)
(Energy Suspension) 4.3121 (2) (Axle Pivot Bushings, 90-96 2WD)
(Energy Suspension) 4.7115 (Track Arm Bushing 85-98 F350 4WD)
(Energy Suspension) See Page (Leaf Spring Bushings)
(Energy Suspension) 4.212G Front leaf spring bushing (black)
(Energy Suspension) 4.7115G Trac arm bushing (black)
(Energy Suspension) 4.5126G F350 Sway bar bushing (black)
(Energy Suspension) 4.2114G -Rear leaf spring bushing w/ common type bushing (metal outer sleeve).. (black)
Bushings, Radius Arm, Plastic insert spacer, not included with Energy Suspension Kits
(Ford) E5TZ-3B244-A (2wd, 2 needed)
Camshaft Bearings, up to 8/1995, maybe later.
(International) 1812317-C92
Camshaft Position Sensor (CPS)
(Ford) F6TZ-12K073-A 94-96 (old)
(Ford) F7TZ-12K073-A 97 (old)
(Ford) F4TZ-12K073-C 94-96 new revised one black in color
(Ford) F7TZ-12K073-B 97-03 new revised one
(International) 1821720C99 (below engine 375548)
(International) 1825899C93 (above engine 375548)
Camshaft Position Sensor (CPS) O-Ring
(Ford) F81Z-12B615-BA
(International) 1824948C1
Camshaft Position Sensor (CPS) shim kit
(International) 1826583C91
Catalytic Converter Delete Pipe
(Ford) F4TZ-5A212V
(Ford) XC2Z-5A212-AA (SD type, cheap but must be shortened)
Clutch
(LuK) 07-154TFW (replacement 12" used w/SMFW; incl. SMFW)
(LuK) 07-127 (12-1/4" clutch replacement)
Clutch Master Cylinder
(Ford) F2TZ-7A543-D (96-97)
Clutch Release Fork (Lever Assembly)
(Ford) E7TZ-7515-A
Clutch, Throwout Bearing
(BCA) FC65662
Coil Spring Shim, Height adjusting/leveling, F250 2wd
(Ford) 389117-S2 (service part, washer goes under coil spring)
Column parts - see steering and shift
Coolant Supplemental Additive
(Fleetguard) DCA5
(Ford) FW-15/FW-16
(Motorcraft) VC8
Coolant reservoir de-gas bottle
(Ford) F6TZ-8A080-EA (late OBS style)
(Ford) 2C3Z.8A080.AA (SD above radiator style)
Coolant Temp Sender
(Ford) F1SZ-10884-A (for gauge, mounts on water pump)
(Fordf) F4TZ-10884-B (for overheat light, RH front of block)
Coolant Test Strips
(Fleetguard) CC6202 (50)
(Fleetguard) CC2602A (four strips)
(Fleetguard) CC2602B (one strip)
Crankcase Breather (CCV) O-Rings
(Ford) F4TZ-6769-A (small; seals screw head; 1/pack)
(Ford) F4TZ-6769-C (large; seals breather adapter to valve cover; 2/pack)
(International) 1824452C2 (Small, 2 needed)
(International) 1820784C2 (large, 3 sided, 2 needed)
Dana 50 TTB Hub Lock Nut Tool
(OTC) 7158
Dana 50 TTB
(Ford) F6TZ-3N105-BB (spindle nut, washer, gasket, autohub bolt, retainer kit)
(Dana/Spicer) 708084 (spindle needle bearing and both seals)
(Dana/Spicer) 48816 (wheel bearing seal)
(Dana/Spicer) 660568 (spindle nut with pin)
(Dana/Spicer) 621028 (spindle lockwasher)
(Dana/Spicer) 621027 (spindle nut w/o lockwasher)
(Dana/Spicer) 706411X (inner wheel bearing and race)
(Dana/Spicer) 706074X (outer wheel bearing and race)
(Napa) BK1 (spindle bearing, inner & outer seal rebuild kit)
(Napa) 22311 (inner spindle)
(Napa) 711818 (outer spindle)
(Napa) 27452 (hub seals)
(Napa) B2110 (spindle bearings)
(Timken) 382A (wheel bearing; inner race)
(Timken) 387A (wheel bearing; inner bearing)
(Timken) SET38 (wheel bearing; outer bearing w/race)
(BCA) SET A-38 (Wheel Bearings)
(National) 415690 (wheel bearing seal)
(Chicago Rawhide) 27467 (wheel bearing seal)
Dana 60
(Ford) E0TZ-3C140-B (Spindle to knuckle bolt)
(Ford) B8TZ-4322-A (Spindle to knuckle nut)
(Dana/Spicer) 706047X (Carrier Bearing/Race)
(Dana/Spicer) 706046X (Inner Pinion Bearing/Race)
(Dana/Spicer) 706045X (Outer Pinion Bearing/Race)
(Dana/Spicer) 76659-1X (left axle assy)
(Dana/Spicer) 76659-2X (right axle assy)
(Dana/Spicer) 52148 (Inner axle seal) (updated)
(Dana/Spicer) 42449 (Pinion seal)
(Dana/Spicer) 700014 (Spindle bearing & seal kit)
(Dana/Spicer) 49803Outer axle stub (30 spline
Axle U-joints (greaseable)...3-0332...Neapco
(Ford) E5TA-3A094-AA (Trac bar frame bracke)
Inner spindle grease seal '92-'97...BRS-87...Motorcraft also F2TZ-1S175-CA...Ford
(Ford) F81A-5598.DB (4" Blocks)(on block)
-F250/350 Outer hub bearing/race '94-'97...A-38...BCA/Fed Mog
-F250/350 Inner hub bearing '94-'97...387A...BCA/Fed Mog
-F250/350 Inner hub race '94-'97...382A...BCA/Fed Mog
-F250/350 Inner hub seal '94-'97...415960...National/Fed Mog
Steering Components
(Moog/Fed/Mogal) ES3009R F350 (driver's side tie rod '94-'96)
(Moog/Fed/Mogal) ES3009R F350 (Pitman arm to tie rod '94-'96)
(Moog/Fed/Mogal) ES2012S F350 (Sleeve '94-'96)
(Moog/Fed/Mogal) DS1068 F350 (Pitman arm to passenger side tie rod '94-'96) (Moog/Fed/Mogal) DS1071 F350 (Steering arm to steering arm connecting tie rod '94-'95)
(Moog/Fed/Mogal) K80026 F350(Upper Ball joint '94-'97)
(Moog/Fed/Mogal) K8607T F350 (Lower Ball joint '94-'97)
(Moog/Fed/Mogal) K8958 F350 (0* Camber/Caster bushing '94-'99)
Double Cardan Front Drive shaft
-U-joint C.V. joint grease able
(Neapco) 2-4800HD...
(Spicer)5-213X
U-joint yoke side greaseable
(Neapco) 2-4900HD
(Spicer )5-231X
C.V. centering assy...R2-21-1179...
Dash Pad
(Ford) F2TZ-1504282-BAD (mocha/tan)
(Ford) F4TZ-1504282-AAY (light grey)
Dash repair kit for right (passenger's) side dash mount. Frequently get broken.
(Ford) F4TZ-1504366-A
Daytime Running Lights Module (Ford) F43Z-15A272-A (Check Ebay)
Door Latch
(Ford) F2TZ-1521813-A
Door Darts (Inside Panel Push Fasteners) (also available at almost any parts store)
(Ford) N802900-S
Door Inside Panel
(Ford) F4TZ-1523943-BAD (mocha/tan)
Door panel light (clear lense)
(Ford)F2TZ-13734-B (Driver's side )
Door Weatherstrip, Drivers side inside belt molding, Felt strip inside that window rubs against
(Ford) F2TZ-1521457-A
Dipstick
(Ford) F4TZ-6750-E (F-Series)
(Navistar) 1824405C1
(Econoline) F5UZ-6750-A
Dipstick Mount Seal Repair Kit with instructions
(International) 1846146c91 (silicone, loctite gasket eliminator, adapter gasket, dipstick o-ring)
Dipstick Tube O-Ring
(International) 875519C1
Engine Belt - See Serpentine Belt
Engine Cover, Front - See Timing Cover
Engine Top Cover
F81Z-6A949-AA (late 97 up medium size)
F81Z-6A955-AA (Plastic cast bracket for med size cover above)
YC3Z-6A949-AA (smaller 2000 up cover)
YC3Z-6A955-AA ( stamped sheet metal bracket for smaller cover above)
Engine Top Cover Nuts
(Ford) N800475S101
Engine Oil Temp Sensor (EOT) - See "Oil Temp Sensor"
Engine Oil Pressure Sensor (EOP) - See "Oil Pressure Sensor"
Engine, Shortblock
(International) 2504315c91 96-97
Exhaust Back Pressure Regulator (EPR solenoid; up to 98.5)
(Ford) F5TZ-6C673-A
<hr>
Exhaust Back Pressure Regulator Valve EBPV
(Ford) (old F4TZ-9J460-A) (new 1C3Z-9J460-AA) (94-96; mounts on bracket above oil reservoir)
(International) 1825685C1 (early)
#52
At $17-22 each, including a new bulb...That's about as cost effective as one can get for getting rid of the 19 yr old yellowed lights...
#53
on
From Silverstate Ford Parts, a site sponsor......
<table border="0" cellSpacing="0" cellPadding="3" width="100%"><tbody><tr><td class="titletext">SHOPPING CART</td></tr></tbody></table>
<table style="border: 1px solid rgb(236, 235, 233);" border="0" cellSpacing="0" cellPadding="3" width="100%"><form method="post" name="updateQuantity" action="index.cfm?action=updateQuantity&orderitemc ount=1&siteid=214290"><tbody><tr><td class="tableText" vAlign="top" width="5" align="left"> </td><td class="tableText" vAlign="top" width="40%" align="left">Description</td><td class="tableText" vAlign="top" noWrap="" align="right">MSRP Price</td><td class="tableText" vAlign="top" noWrap="" align="right">Your Price</td><td class="tableText" vAlign="top" noWrap="" align="right"> </td><td class="tableText" vAlign="top" noWrap="" align="right">Core Price</td><td class="tableText" vAlign="top" noWrap="" align="center">Qty</td><td class="tableText" vAlign="top" noWrap="" align="right">Total Cost</td><td class="tableText" vAlign="top" noWrap="" align="center"> </td></tr><tr><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" width="5" align="center"> </td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" align="left">Collision Catalog - 1996 - Ford - F-250
body hardware, front bumper, bumper & components, face bar turbo diesel, w/impact strip </td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" vAlign="middle" align="right">$532.13</td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" vAlign="middle" align="right">$376.75</td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" vAlign="middle" align="right"> </td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" vAlign="middle" align="right">$0.00</td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" vAlign="middle" align="right"><input style="text-align: center;" class="textbox" name="qty1" maxLength="4" value="1" size="2" type="text" required="No"></td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" vAlign="middle" align="right">$376.75 </td><input name="Cartitemid1" value="6083515" type="hidden"> <td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" vAlign="middle" align="center"> </td></tr><tr><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" colSpan="7" noWrap="" align="right">Sub Total:</td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText" align="right">$376.75</td><td style="border-top-color: rgb(236, 235, 233); border-top-width: 3px; border-top-style: double;" class="tableText"> </td></tr><input name="Cartitemcount" value="1" type="hidden"> </tbody></form><tbody></tbody></table>
<table border="0" cellSpacing="0" cellPadding="0" width="100%"><tbody><tr><td class="normal">If you change quantity, please click Recalculate.
<table border="0" cellSpacing="0" cellPadding="3" align="center"><tbody><tr><td class="normal" vAlign="middle">RECALCULATE</td><td class="normal" vAlign="middle"> </td><td class="normal" vAlign="middle">EMPTY CART</td><td class="normal" vAlign="middle"> </td><td class="normal" vAlign="middle">ADD TO FAVORITES</td><td class="normal" vAlign="middle"> </td><td class="normal" vAlign="middle">SHOP MORE </td><td class="normal" vAlign="middle"> </td><td class="normal" vAlign="middle" align="center">CHECKOUT </td></tr></tbody></table></td></tr></tbody></table>
<table border="0" cellSpacing="0" cellPadding="0" align="center"><tbody><tr><td class="normal" align="center">View our Shipping policy View our Return policy </td></tr></tbody></table>
<table border="0" cellSpacing="0" cellPadding="0" width="800" align="center"><tbody><tr><td class="normal" align="center">
#54
on
Btw, thats a generic bumper diagram. The turbo diesel bumper referred to does, in fact, have the holes. The holes were actually put in the bumper to help provide the copious amounts of intake air the 7.3 trucks needed. The exception, as I stated previously, was the FSuperDuty (450) line which sat much higher and did not have the plastic air dam...hence providing enough air without the holes in the bumper.
#55
I've got a 95 XLT and it has a regular chrome impact strip bumper. My 96 Eddie Bauer that I bought brand new had the "hole" "diesel" or whatever bumper.
However, the thread is about lighting, and not about bumpers, or if Brad will argue a point because he thinks he's right (because we all know he will).
Getting back to lighting, I've got some PIAA combination driving/fog lights that I've had for a few years now. Had them on my 93, just mounted to the bumper, and they worked great. I haven't mounted them on my 95 yet, because I need to replace the front bumper.
#57
#58
#59
Whatever Brad, heres the full version. When I wanted the "hole bumper" for my F450, they had to source it by referring to it as bumper, diesel. If I felt ambitious I would find the invoice. For now, this seems to be the only tangible evidence of my experience. Perhaps Number Dummy can shed some light.
#60
Came in Keystone Styling boxes...
Essentially with that site, you eliminate the middle man.
