Engine Horsepower. 5.4 vs 5.0
Old 03-20-2013, 12:31 PM
Stangfire's Avatar
Stangfire
Stangfire is offline
Question Engine Horsepower. 5.4 vs 5.0
How much HP is the 5.0L?
How much HP is a 2010 5.4L Triton?
How much HP is a 2003 5.4L Triton?
Thanks.
Old 03-20-2013, 01:18 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
Stangfire -
  • 360 hp @ 5,500 rpm
    380 lb.-ft. torque @ 4,250 rpm
  • 320 hp*
    390 lb.-ft torque*
    *Requires E85 fuel
  • 260 hp
    350 lb.-ft torque
Information excerpted from pertinent sales brochures.
Reference: Ford Truck Brochures ««« -click-
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old 03-20-2013, 02:40 PM
03 SVT VERT's Avatar
03 SVT VERT
03 SVT VERT is offline
The 2010 5.4L was 310hp/365ft-lbs on gas.
Old 03-20-2013, 03:01 PM
Stangfire's Avatar
Stangfire
Thanks. So I should notice a big jump in power from a 2003 5.4L to a 2011 5.0
Old 03-20-2013, 03:51 PM
03 SVT VERT
Definitely. The 5.4L is a very torquy engine and, because it's not drive-by-wire, has a little better throttle response than the 5.0L. However, the 5.4L pretty much dies in the upper rpm range.
The 5.0L is a much better balanced engine. Plenty of torque down low, but also breaths well up high. It's a great engine and it will leave the 5.4L in its dust if you put your foot down.
Old 03-20-2013, 07:49 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
03 SVT VERT - Definitely. The 5.4L is a very torquy engine and, because it's not drive-by-wire, has a little better throttle response than the 5.0L. However, the 5.4L pretty much dies in the upper rpm range.
AND ... The 5.0L is a lighter engine - 435Lbs versus 525Lbs.
-click- the pic'
Goth 150
Old 03-20-2013, 09:26 PM
dave91gt's Avatar
dave91gt
dave91gt is online now
I have both- sort of. I have a 2012 FX4 crew with the 5.0. Wife has an 08 Expedition with the 5.4 6 speed. Gears in the truck are 3.73 and the Expy has 3.31's so not a direct comparison per say. But I will say the characteristics are obviously different between the engines. The truck will lay blackmarks on dry roads and the Expy will not spin in the rain. Again, not a fair comparison. But, at no point in the powerbands of both engines does the 5.4 even feel like it is more powerful. May be close mid range for a few rpm. But, the 5.0 differs in that once it hits higher rpms there is an increased surge in power, where the 5.4 just seems to stop pulling. Also, the Expy downshifts on every hill that the 5.0 holds 6th and can even accelerate without downshifting. Again, may be the gears. But the wife tried to keep up getting on the interstate from about 10 mph. I punched it and the rear tires broke free. Once the 5.0 hooked up I put several lengths on the Expy by 70 mph. I know it sounds like I am downing the 5.4. Im not. The 5.4 6 speed is a great combination. If I had never driven a 5.0 I wouldn't know better. But, I would love to see the Expy get the 5.0.
Old 03-21-2013, 01:29 AM
blueovelboy's Avatar
blueovelboy
blueovelboy is offline
OK to be fair the 5.4 with the six speed (09 and up) was a big jump from say your 2008 and older 5.4's. my 07 was way behind my 2010 5.4 i had and my 2012 5.0 is a jump up from that! that six speed makes a world of difference but the 5.0 is a beast!
Old 03-21-2013, 07:22 AM
Stangfire's Avatar
Stangfire
Thanks guys. I'm definatley gonna look for a 2011 with the 5.0L
My 2003 5.4L just doesn't do it for me anymore.
Old 03-21-2013, 08:35 AM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
My '12 5.0 is way better off the line than my 5.4 was. The 5.4 in my 08 felt like it had a turbo spooling up when given the go pedal. The '08 5.4's were drive by wire also, (I had to change my TPS) and my 08 was still quicker off the line than my '02 5.4.
Old 03-21-2013, 09:08 AM
Jimbits78's Avatar
Jimbits78
Jimbits78 is offline
My 05 was better and quicker than my 02
My 10 is better and quicker than my 05.
My buddies 12 5.0 is quicker than my 10 (not better)
The 02 was gutless compared to the 05. The 05 was great until I drove the 10. The main reason the 10 is so good is the 6 speed tranny. If you got any f150 09-up you would be happy. It's more the transmission that is making the difference not the engine.
My idea truck would be my 5.4 with my buddies 12 tranny. Yes the 5.0 is quicker and is more like driving a mustang than a truck but when we are both hooked to trailers I prefer the lower revving characteristics of my 5.4 over his 5.0.
Old 03-21-2013, 09:49 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
the 10 and 12 trannys are the same six speed. What are you thinking you will gain?
Old 03-21-2013, 09:50 AM
Jimbits78's Avatar
Jimbits78
Gaining the select shift!!!!!!
Old 03-21-2013, 10:03 AM
Stangfire's Avatar
Stangfire
So 2010 came out with the 6 speed tranny?
Edit: never mind. I re-read the posts. 6 speed came out in 2009.
Old 03-21-2013, 02:57 PM
640 CI Aluminum FORD's Avatar
640 CI Aluminum FORD is offline
I own a 2011 FX4 Supercab 5.0L and I've driven my share of 5.4L's over the years...Everything from the old 2v 5.4L all the way up to the 3v 310hp ones.
There was a signifigant difference between the 2v 260hp 5.4L and the 3v 310hp 5.4L but I think it was mostly related to the 6-speed tranny vs the 4-speed in the old unit.
I can comfortably say though, Without question that the 5.0L is superior any of the 5.4L's I've driven in every way. The only 5.4L I've ever driven that I think may have given the 5.0L a good run was a friend of mine who had some work and a 5-star tune on his. He was laying down 14.5 to 15.0 1/4 miles, but it was not stock. Most 5.0L F-150's I've seen run about those times without having a tune or any work done to them. The 5.0L in my experience feel's equally as torqy in the lower/mid range as the 5.4L does...But loads more powerful in the mid/high range, and ontop of that it gets better mileage. The 5.4L's a great engine, and I've seen some that went well past 400,000 miles...I hope that the new 5.0L will share the same reliablity charcteristics of the 5.4L...But only time will tell.
Quick Reply: Engine Horsepower. 5.4 vs 5.0
