1985 f250 460 air injection and egr help
So the po of my truck messed up the routing of all my vacuum lines when he swapped to an edebrock 1406 and I have to get the egr and air injection working to get emissions. The 2 pumps are good and have belts in place, my question is the valves that controll the airflow, they have two nipples for vacuum lines, one is on underside and the other is a little bigger on the side of the valve, do both of the nipples need ported vacuum to operate and is it that simple. Also the egr line, is it as simple as feeding it ported vacuum also? Any help is greatly appreciated.
Post a picture of your Vehicle Emissions Control Information sticker on your radiator support under the hood and somebody here can tell you more. No, it's not as simple as what you're describing, these things are controlled by temperature-actuated vacuum control valves.
Here is my sticker for reference:
craigdallen
32
10-13-2014 05:28 PM
Soarer
03-29-2014 09:40 PM
