1976 f250 460cid spitting and sputtering
Old 03-18-2013, 12:46 PM
KristopherNorth's Avatar
KristopherNorth
KristopherNorth is offline
I have a 1977 f250 with a 1976 460cid that is spitting and sputtering at about 2000rpm. Rebuilt the carb, New vacuum advance, New plugs, wires, cap and rotor. Checked timing. Fixed exhaust leaks. Wasn't spitting before I replaced everything and seems to be getting worse with everything being done. Any ideas as to what could be causing this?
Old 03-18-2013, 01:15 PM
redroad's Avatar
redroad
redroad is offline
Just going to ask a few questions to make sure they were checked ..
1) Choke is opening when motor reaches operating temp
2) Fuel filters changed
3) Fuel pressure is good/fuel pump is good
4) power valve was replaced when carb was rebuilt
5) float level was set at rebuild
6) what carb are we talking about ?
7) all vaccun lines are connected
Old 03-18-2013, 01:35 PM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is offline
I would say to double and triple check the firing order and make sure the wires are all in the correct order.
Old 03-18-2013, 09:21 PM
KristopherNorth
Everything done so far.
At this point, We have replaced the manifold gasket, plugs, wires, cap n rotor, vacuum advance, vacuum lines, rebuilt carb, new exhaust and set timing. The shop working on it is now saying that it sounds like valve timing???
Old 03-18-2013, 11:00 PM
redroad's Avatar
redroad
redroad is offline
Was any work done on the internals of the motor?
Old 03-18-2013, 11:19 PM
KristopherNorth
Not as of yet...
Old 03-19-2013, 10:05 AM
wdfp's Avatar
wdfp
wdfp is offline
If it wasn't doing it before something was done but it is afterwards, it's usually a pretty safe bet that whats causing it is something that was done to it. Just because somethings new does not mean it is good, almost sounds like a crossfire deal. Cracked cap or wires shorting to each other. Run it after dark and watch as you rev it up to see if any sparks jump from the wires. A cracked cap can be almost impossible to see sometimes too..
LIF150
09-12-2011 03:59 PM
55Bubba
13
11-10-2004 12:38 PM
55Bubba
10-15-2004 07:09 AM
Sirhcpordlaw
18
10-11-2004 12:34 PM
Quick Reply: 1976 f250 460cid spitting and sputtering
