87 f150 no start
Old 03-12-2013, 01:38 PM
JOCKSTU7's Avatar
JOCKSTU7
JOCKSTU7 is offline
87 f150 no start
parked it last night wont start today. fuel at the rail.
Old 03-12-2013, 01:42 PM
str8sixman's Avatar
str8sixman
str8sixman is offline
Not a whole lot of info to go on, you got spark?
Old 03-12-2013, 01:47 PM
JOCKSTU7's Avatar
JOCKSTU7
JOCKSTU7 is offline
NO, I CHANGED BOTH FUEL AND IGNITION MODULES(BY THE AIR FILTER, I HAD THEM FROM PREVIOUS PROBLEMS)
Old 03-12-2013, 02:05 PM
88n94's Avatar
88n94
88n94 is offline
You changed the ignition module on the side of the distributor? That would leave the coil and the pickup inside the distributor. First make sure you are getting power to the coil through one of those small wires that hooks onto the coil, with the ignition switch turned ON.
You have no spark, right?
Old 03-12-2013, 03:01 PM
JOCKSTU7's Avatar
JOCKSTU7
JOCKSTU7 is offline
GOT IT THANKS, IT WAS A FUEL PROBLEM, LOW PRESSURE
Alex Taylor
09-10-2017 06:17 PM
Neptunestriton
02-17-2014 08:19 PM
saezjose
Bronco II
01-18-2010 04:31 PM
idratherbedriving
08-09-2004 09:42 AM
lc501
09-29-2003 09:35 PM
Quick Reply: 87 f150 no start
