My 1970 F100 Flareside (Pic Heavy)
#376
Received 5,160 Likes
on
#377
OK, the Pertronix Ignitor 1261 was the correct one. I installed it with a spare Standard brand coil I had. I was able to retard the timing a bit and lower the idle screw on the carb to get a nice smooth idle. I also swapped out the vacuum advance to one that held vacuum from a spare distributor I had.
I have not taken it for much of a drive yet since the wife is at work and the minion was busy. Only a quick romp through the neighborhood. It is not huge difference but it is a noticeable one.
Next will be the carb rebuild. Just waiting for the kit to get here so I can send it out.
#379
Update: After some mishaps and some head scratching, we have the carb rebuilt and working. It still needs a touch of adjusting, but it is running smooth. Jeff rebuilt if for me.
All Hail the King II!
It has been an interesting couple weeks... err, wow it's been a month since my last post.
I finished the install on the cluster and have finally removed all unwanted under dash addons. I have replaced the U-joints finally and got rid of the annoying vibration. I thought it was something else, glad they fixed it. I have been trying to embrace my inner 'patina' and even started cleaning up the truck. I cleaned 45 years of dust and dirt from the dash, and even started to wax the body. I was surprised how much of a difference it made. The hood glare will take some getting used to.
Here are few pics so you can compare to when I first got it and now. The old pics can be found early on in the thread.
#381
#383
on
#385
currently using Meguiar's Cleaner Wax. It helps get through the years of oxidation and bring some shine back. It also gives a good long lasting wax coat.
Some people have used cleaners such as Bon Ami to remove the stains, and oxidation from the paint. I use the cleaner was so it's all done at once.
It is not a long term thing for me, since I plan to paint the truck. Just trying to make it better in the meantime.
#386
Hey everyone. Sorry I have been gone for a while.
Things have been busy around here with life issues. The heat has kept me from doing much with the truck. I still have things I can do when the temps allow.
I really hope to get AC by next summer. It has been so hot, that it is hard to even enjoy driving the truck.
My friend Dave donated a fan shroud from his 78/79 Bronco build since he switched to electric fans. It looks to have been trimmed several times.
The only trimming I had to do was notching for the harmonic balancer. It fit but only had about 1/32 clearance. I knew once air was funneling through it would have hit.
It's a snug fit but cleans the engine bay up more than I was expecting.
#390
