07 F350 SD Diesel Center Seat
Is there any way to move the center seat/console area? My husband had surgery on his leg and is in a full cast on his right leg. We can put the driver's seat back but the center section doesn't seem to move and if it was back just a little more he'd have room to put his cast so he could drive.
Wow, sorry to hear about your husband.....hope he's recovering pretty well.
I agree with Dan. The easiest solution to this is probably to just remove the entire center section for the time-being until he gets the cast off and then put it back in once he's healed.
These threads may help a little:
https://www.ford-trucks.com/forums/7...ns-chairs.html (Last post)
https://www.ford-trucks.com/forums/8...h-6-speed.html (Post #33)
These will at least give you an idea of what you're looking at to remove the center section. For what it's worth, I think the seat brackets overlap the brackets for the center section, if I recall correctly.
Awitte58
07-05-2012 07:38 PM
