Installing front lift shackles with pictures
Old 03-09-2013, 09:56 PM
EXv10's Avatar
EXv10
EXv10 is offline
These pictures are too big to expand.
This is the stock and 1 1/2" lift shackle below;
Here it is again;
2000 Ex 4WD 160k miles;
Doing one side at a time;
Yep, it's me
The little 6 ton jack got a workout today;
I had to drop the sway bar and pull the shock tops;
You will need a little jack like this to fine tune the spring height;
The little jack is on the bottom here;
This is the drivers side and I had to loosen the 4 axle u-bolt nuts to get the spring to line up.
The bump stop only had 1/2" clearance but now it has 2";
It looks level to me, I measured at the bottom of the windows and it was the same all across. I don't have a before picture but it was 1 1/2" lower in the front;
Here it is again with Mt. Shasta in the background. I'm looking forward to plowing into some deep dips and the soccer-mom ride is fully retained.
Old 03-09-2013, 10:01 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Bravo, nicely done Brent! Great pics too; though we expected no less. Hopefully it wasn't too cold out there - looks like the snow was melting today.
Old 03-09-2013, 10:19 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Um wheres the pics ?
Old 03-09-2013, 10:48 PM
EXv10's Avatar
EXv10
EXv10 is offline
Hang on guys you responded as I was working on it. It posted before I was all done. (probably because I edited it half way through). The pictures came out too big but Pbucket is not working with My windows 8 so I went with Imgur........seemed to work. Go back again.
Old 03-09-2013, 10:54 PM
Bigpipes 35
Originally Posted by EXv10
Hang on guys you responded at I was working on it. It posted before I was all done. (probably because I edited it half way through). The pictures come out too big but Pbucket is not working with My windows 8 so I went with Imgur........seemed to work. Go back again.
Looks awesome. and on a side note are you front mudflaps mounted on the wrong side ?
Old 03-09-2013, 11:35 PM
EXv10's Avatar
EXv10
EXv10 is offline
I don't know, I just got some cheap universal ones from ebay and screwed them to the fender well. They stick out about 3" but they keep my running boards clean.
Old 03-10-2013, 03:58 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
Good work! Hope she ended up like you wanted her to!
Old 03-10-2013, 06:27 AM
sammie0126's Avatar
sammie0126
sammie0126 is offline
That is a beautiful background for working on your Ex. Sure beats the cornfield backdrop of the midwest. Nice photos
Old 03-10-2013, 06:31 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
looks great! really helped the stance of your truck. i know i love my shackles and i've had them on going on 3 years! part of me likes keeping the stock springs. i never did loosen the shock though.
man, doing it outside i admire your will power. i love having a heated garage with air tools and a awesome sound system to do my projects.
glad you got some pics up, i love white and you live in a beautiful area!
Old 03-10-2013, 10:38 AM
EXv10's Avatar
EXv10
EXv10 is offline
The new Monroe -matics extended an inch before full body height. It wasn't that cold but my legs kept getting in the snow.
Old 03-10-2013, 11:12 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
are your front mudflaps mounted on the wrong side ?
Take a look at Brent's signature; they're custom.
Old 03-10-2013, 12:50 PM
EXv10's Avatar
EXv10
EXv10 is offline
Yep, I cannot lie.
Old 03-10-2013, 04:55 PM
Bigpipes 35
Dangit I missed that part...
Old 03-11-2013, 02:12 PM
EXv10's Avatar
EXv10
EXv10 is offline
Bumpety bump
Old 03-11-2013, 03:17 PM
tdappleman's Avatar
tdappleman
tdappleman is offline
Looks good - what kind did you go with? I may be doing this soon - down to an inch of spring travel as well.
Quick Reply: Installing front lift shackles with pictures
