1982 C6 swap to 1985 AOD?
The parts book says you should have at least two wires down at your C6, these will be for the backup lamps.
Here is the switch, E0TZ-15520-B Motorcraft SW-1579 SWITCH ASSY. (BACKUP LAMP) Marked E0TP 15520-BC
Fits 1980/82 all pickups & Broncos (vans use a different one) w/C6 transmission
If you don't have any wires down there at all, something is wrong and I'd like on the harness for remnants. A 1980 truck has the NSS at the steering column.
This stuff won't affect your installing an AOD, it's just that you won't have backup lamps.
I assume you are looking for better fuel economy. Search on the posts for AOD and TV cable/rod setup before deciding if it is worth the effort.
Yes I am looking for better economy. I have a put a Holley 650 on, but I will be able to figure the tv cable out.
I looked at the wireing harness yesterday and saw plugs hanging where the transmission is, today I will compare them with the 1985 AOD. If it is just the reverse lamps it's not that big a deal
bigcountry1985
12-28-2010 03:08 PM
lakecityg
03-15-2006 08:05 AM
