1960 Super Duty Crew Cab build thread
Old 07-08-2015, 06:15 AM
Cracker289's Avatar
Cracker289
Cracker289 is offline
Originally Posted by 78_f800crewcab4x4
U
Dude, that is a super cool Super Duty truck you're building up! You got the vision you got the plan
  #137
Old 07-10-2015, 11:08 AM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
So many awesome things about this build.
More pics please!
  #138
Old 07-12-2015, 10:51 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
Custom rear cab mount uses 1979 bronco style mounting hardware and polyurethane insulators.
The following users liked this post:
  #139
Old 07-13-2015, 01:20 AM
54Hydro's Avatar
54Hydro
54Hydro is offline
Subscribing.
I wish you guys lived a hell of a lot closer. I would love to learn bodywork.
Badass truck. I normally don't care much for this body style but exceptions happen.
  #140
Old 07-13-2015, 09:18 PM
78_f800crewcab4x4
I'm not doing a restoration at this time, so you will see clean fresh stuff bolted to rusty surfaces. Just trying to get this back on the road!
Another shot of mount
Installed on frame. It helps to have the rear floorpan out.
  #141
Old 07-14-2015, 06:48 PM
78_f800crewcab4x4
The old door limit strap bracket had broken off inside the pillar, so I drilled four holes where the old spot welds were. Then spot blasted off the corrosion and paint.
Plug welds and an econoline door prop.
Now both doors prop open with a click so I can continue working.
  #142
Old 07-16-2015, 01:47 PM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
So many pairs of pants were changed in the viewing of these pics...
  #143
Old 07-16-2015, 07:07 PM
78_f800crewcab4x4
NOS door locks.
  #144
Old 07-16-2015, 07:12 PM
78_f800crewcab4x4
Nos ford keys. These have a lot of detail.
  #145
Old 07-16-2015, 07:23 PM
spurredon's Avatar
spurredon
spurredon is offline
You gotta love that style of key! I use one in my truck.
  #146
Old 09-09-2015, 12:31 AM
No_Respect's Avatar
No_Respect
No_Respect is offline
This is Epic!
  #147
Old 09-10-2015, 03:10 AM
78_f800crewcab4x4
Newly made rubber air brake hoses from the cans to the valves, front and rear all the same. New copper-nickel hard lines run from one tank to the spring brake valve and out to the spring brakes. New copper-nickel fuel line from the refurbished gas tank to the engine. Also ran the same hardline from the new clutch master to the slave cylinder, and from supply air to the air horn.
Judging by the DOT tags on the old air hoses, and the stamps on the nylon spring brake lines, the brakes had been worked on in January, 1979.
  #148
Old 09-12-2015, 01:07 PM
spurredon's Avatar
spurredon
There is always so much unseen work that needs doing.
  #149
Old 09-12-2015, 10:00 PM
78_f800crewcab4x4
Getting the dash together. Chrome gauge cluster. A few new ***** and switches.
  #150
Old 09-12-2015, 10:06 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Rusty_Old_F250 is offline
Looks nice! The tach and speedo are from a 70s f500+ right? I always thought they were the best looking gauges.
Sam
Quick Reply: 1960 Super Duty Crew Cab build thread
