Lights and Wiring
Lights and Wiring
I'm going to be putting clearance lights on the top of my cab, and maybe 3 small amber lights in the grille (like the F150 Raptor). I may also have extra tail lights to hook up on a headache rack. I would like to wire the lights into the system with the regular lights. I want to wire them to come on when the side clearance lights and tail lights turn on.
Does anyone know how much extra capacity there is in the relay/fuse/wiring? I don't mind putting in a higher capacity relay/fuse or whatever, but I don't want to do that and then burn up wiring...
I have fog lights and off-road lights wired into separate switches, but I would rather not have another switch for these accessory lights.
Thanks in advance!
Thanks in advance!
Can I buy a relay "box" or "holder" to put the new relay(s) in? Or should I just find a safe spot under my dash and hook quick connects onto it or solder to it?
I would just screw the relay on as in the photo below.
Disregard the writing in the photo, just showing how I mounted two relays.
Thanks for the help!
I do not know what the amp cap is on that one.
Here is the one I used, NAPA #AR113
NAPA AUTO PARTS
NAPA AUTO PARTS
NAPA AUTO PARTS
NAPA AUTO PARTS
I got the lights and relay today. I'm not sure where to tap into the switch for the main lights. I want my clearance lights to come on when the amber side marker and tail lights come on, and I want them to be on when the main driving lights are on. So, in other words, I want them to be turned on with the first and second stop in the stock headlight pull switch.
Do you know the wire color and location to tap into that switch for it to operate the relay? I can't find a relay that "clicks" when turning the lights on/off. Do the main lights run straight off of the switch without a relay? If so, I'll check the fusebox tomorrow and use an "add a fuse" and run the wire off of that to operate my new relay.
Bill, you mentioned using power off the coil to the relay. I have an accessory fuse panel mounted under my dash that I put there not long ago. I'll run power to the relay off of that.
Thanks
I would not put an extra load on the light switch and that is why the relay. The light switch and plug melt already a lot of the times. If any thing I would also relive some of the load off the brown wire that it has now.
The wire color is brown as I said above but I do think I said anything about taking power off a coil to a relay to do anything.
If you put the relay under the hood I would tap the brown wire at C100 in the engine compartment.
If you put the relay inside the cab I would tap the brown wire at the warning buzzer.
See the diagran below.
