So I'm trying to figure what speedo gears to use and I can't find what the rpm of the fridge speedometers is. Virtually all the online calculators want this info. I'm guessing it's 1000 but I can't be sure. Any ideas? Thanks
Are you using the original speedo and transmission? If you are, Fords parts book will tell you which speedo drive and driven gear to use (for a given tire size).
