Max boost on a stock turbo?
well Im not going over 25 psi every single day, think it will last awhile if its just the occasional playing around and racing and only hitting 30 psi every once in awhile? btw what is IIRC?
I will be honest.. i freaked out a little. I got paranoid about smelling anti freeze.. haha
Guess my new wheel makes too much powa!!!
IIRC it took ziggy 48 or 50psi w/ his H2E to pop his headgasket..
If I Remember Correctly
After my DP tuner let me go past 30psi on the 80e tune I called Jody to ask...10 min later I got a return phone call from him, saying 30 was fine. No additional tuning needed. No worries unless I'm running high egt.
With that much psi it's just creating heat. Your IC will be required to actually work.
I'd check shaft play in turbo because if its on its way out, 30+ psi will finish it off. But if its good, have fun, and check it every oilchange.
Where did you get such info? I never really knew where the line was. I slammed 36psi last night and I've never been over 32psi..
I would rather spend the extra money on studs then have to worry which hard hit to the throttle is going to be the one to pop the heads.
