1994 f-350 7.3 idi turbo won't start
Old 02-12-2013, 04:18 PM
94iditurboNY's Avatar
94iditurboNY
94iditurboNY is offline
I just bought a 94 f-350 idi turbo, it started great when bought, and for about 3 days after that, then one day it would not start, had batteries tested and one was bad, bought a new battery and it started again and started for about 5 more times that day no problem. Went to work it sat for 8 hours, went to start it after work it started quickly then died and would not restart. The wts light lights up for 8-10 seconds then goes off, it turns over pretty rapidly but will not start, any suggestions?
Old 02-12-2013, 05:03 PM
79sparky's Avatar
79sparky
79sparky is offline
Is there white smoke coming out the exhaust while your cranking it?
Old 02-12-2013, 05:07 PM
94iditurboNY
i cant see any but its hard to tell it has a straight pipe and i cant see it from my mirror i will check tomorrow having someone crank it over
Old 02-12-2013, 05:18 PM
79sparky's Avatar
79sparky
79sparky is offline
Yah give that a check depending on how the wind is blowing you should be able to see its vaporised fuel so you should be able to smell it soo, if nothing is coming out, make sure you have fuel (not to be a smart ***) make sure none of your fuel lines are leaking, could be your lift pump id replace that first if your lines are good since its cheeper than an injection pump lol
Old 02-12-2013, 05:34 PM
94iditurboNY
ok i will try looking for leaks, just funny it started yesterday morning and wouldnt start last night, well it did start last night, and then it died right out and wouldnt restart
Old 02-12-2013, 05:44 PM
79sparky's Avatar
79sparky
79sparky is offline
Yeah when my lift pump went out it went out, hopefully its not your ip, however if the shower heads broke off in the tank that could be an issue to what's your fuel level at and you try switching tanks?
Old 02-12-2013, 05:49 PM
94iditurboNY
full only has one tank
Old 02-12-2013, 06:13 PM
79sparky's Avatar
79sparky
79sparky is offline
Well its probably not a broken shower head if you wanna drop the tank and check it wouldn't hurt though the lift pump is like 25 bucks and id rather rdplace than drop a full tank if I don't absolutly have too
Old 02-12-2013, 07:24 PM
akamacgyver's Avatar
akamacgyver
akamacgyver is offline
Clueless spectator!
An easy test for lift pump is detach the line back to the tank from your lift pump and put it in a fuel can of diesel and try to start her, If there is no change, then the problem is not from the pump back, but somewhere in the engine compartment. Hard starts after sitting, but not yet cold motor is a classic sign of air intrusion. Do you know if your return lines have been serviced?
FWIW, What sparky says is true, a lift pump is relatively inexpensive, pretty easy to change out, and can eliminate that factor.
Mac.
Old 02-12-2013, 07:55 PM
94iditurboNY
ok my uncle towed it and it started right up ran rough a minute then ran like a champ, i got it home, and let it sit 10 minutes and started right back up, ran great, there is no mechanical pump, prior owner must have installed a electric pump? mechanical pump is still there but no lines? and i dont think the return lines have been touched, im getting a filter tomorrow, and have return lines on order
Old 02-12-2013, 08:01 PM
79sparky's Avatar
79sparky
79sparky is offline
Wouldn't doubt it if that electic pump is on its last leg
akamacgyver
Clueless spectator!
94,
It sounds like you are on the right track. The running rough after pull starting sounds like air in the lines. Hopefully return lines will fix that. make sure you get vitton o-rings. Most kits don't come with them, but they are readily available from McMaster-Carr or Russ, (typefour here) can hook you up with a complete quality kit.
Hope it goes well for you,
Mac.
Old 02-12-2013, 08:11 PM
94iditurboNY
thanks guys for all the help, and pray for me that this fixes it lol should i also replace the olives?
Old 02-12-2013, 08:21 PM
akamacgyver
Clueless spectator!
In a word, Yes. They are relatively easy and cheap to do. Just know, chasing down air intrusion can be frustrating. Hopefully this solves your problem, but it is just a matter of time until you get it figured out.
Mac.
Old 02-13-2013, 06:55 AM
79sparky's Avatar
79sparky
79sparky is offline
Good luck bud let us know what you find
Quick Reply: 1994 f-350 7.3 idi turbo won't start
