Which solenoid?
Which solenoid?
Im thinking one or maybe both of the start solenoids are bad, I found the battery draining short, but now today I went to start the truck, and just a click. Got good voltage in the batteries, and at the starter, and just replaced the small hot wire to the starter. How can I tell which solenoid is bad? I put a screwdriver across the two large terminals on the upper solenoid but it doesn't even click, and it seems like a lazy spark. But when I try it from the key, I hear a click/clunk but can't tell where it from.
That's a relay on the fender. If jumpering the big terminals with a screwdriver does not activate the solenoid (the one on the starter), then the relay is NOT a likely suspect (jumpering basically takes it out of the picture). Have you load tested the batteries, independent of one another? Have you also confirmed that the engine is not locked up?
Both the relay and the solenoid can be tested with a multimeter, which is cheaper than either part.
CharlieLed
08-04-2018 11:15 AM
cadunkle
23
03-14-2018 01:21 PM
MoonpieH2O
07-14-2012 03:01 PM
dieselzen
11-11-2005 10:19 PM
