2wd ZF transmission
2wd ZF transmission
The ZF has a fixed yoke (but you already knew that from the previous posts). The slip yoke is on the driveshaft. I have a LWB regular cab and a one piece driveshaft. It was almost too long for a one piece but it will work. If this is going into a 150 then you will also need a stepjoint for the driveshaft somewhere along the way.
2wd ZF transmission
A step joint
Also adding to the trouble is the ZF is about 6" shorter than the C6 I currently have. Right now I am going to see if there is a 2 piece driveshaft in a 139" wheelbase truck with C6, that should buy me the extra 6" in length since I have a 133" wheelbase. But I guess I have to watch where the center carrier is.
2wd ZF transmission
The ZF is made for the 250 so the u joints are larger than the u joints for the 150. You will have to get a "step joint" to reduce from the transmission flange (or yoke) to go from the larger size to the smaller size, or somewhere else in the drivetrain unless you have a 250 rear on the truck. An auto parts store should be able to help you or if you have to get a new driveshaft made, the shop should be able to help you. I don't know what tranny you currently have but you will probably have to customize the tranny xmember to accomidate the ZF. Good luck. A pain to change but worth it.
loudfords
10-15-2004 01:04 PM
