1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
No 4wd Shift interlock fuse blows 02 f250
Old 01-23-2013, 08:59 AM
Jo Diesel's Avatar
Jo Diesel
Jo Diesel is offline
No cruise, Removed shift interlock soloniod, 4wd does not work, replaced shift motor, and there are no lights on. Removed relays from 4wd circuit and unpluged brake light switch and then replaced blown fuse #34 with a 20 amp fuse and the wireing started smoking. Shut off and quit smoking and fuse blew but I can not find where it came from. Any one have wireing diagram for this
Old 01-23-2013, 05:41 PM
h20thief's Avatar
h20thief
h20thief is offline
I don't have a diagram but I experienced a similar issue. I found the shift interlock was controlled by a fuse that kept blowing. After lots of searching I found, on this forum, the master cylinder was leaking BF all down the wiring harness where they plug into the cylinder and caused a short. I disconnected the plugs and replaced fuses and was able to get the shift interlock to open. What I found was the cruise suddenly doesn't engage but I assume its from the shorted unplugged wire. I have not replaced the connections and my cylinder is still leaking but at least I can get it into gear.
I've been chasing other issues with the suspension so this took a back seat. It's on the to do list but just haven't spent time tracking down parts. This might not fix your issue but it is something to look at. I drive an 02 F250.
Old 01-23-2013, 07:12 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Old 01-24-2013, 08:50 AM
Jo Diesel's Avatar
Jo Diesel
If you look at wireing diagram power goes from fuse to brake position switch. I have the bps unplugged and it still is shorting out.
Old 01-24-2013, 08:54 AM
Jo Diesel's Avatar
Jo Diesel
On another note I had to replace the fuse block about a year ago as it had all kinds of problems and blew the fuese about 3 months later. The truck does have 285K miles and has been beet on, No snow plow though
Cole Nieuwsma
12-03-2015 09:28 AM
srpservices
1997 - 2003 F150
13
10-17-2015 07:36 AM
Upnorthfro
04-09-2012 12:17 PM
gp_supercrew
1997 - 2003 F150
09-22-2007 04:25 PM
bigdaddy30
Electrical Systems/Wiring
06-16-2004 05:41 PM
Quick Reply: No 4wd Shift interlock fuse blows 02 f250
