94' F-250 won't start
Old 01-22-2013, 12:47 PM
heavy_d's Avatar
heavy_d
heavy_d is offline
My 94' F-250 4x4 with the 351 won't start. I cranked it up to let it warm up in the cold weather. It ran for about 3 minutes and then shut down. It did not starve for fuel, just shut off like I turned the ignition off.
The engine will turn over but will not start. I have tried starting with both tanks but neither make a difference.
What should I start looking for?
Old 01-22-2013, 01:53 PM
88n94's Avatar
88n94
88n94 is offline
Most likely you lost spark. You could make sure by cranking the engine over and pulling the coil wire or a spark plug wire and checking for spark. See if the engine will start after about 3 hours, that will give a clue as to which component is bad.
adamssho
15
11-26-2012 08:52 AM
abnjumpmaster
06-10-2012 09:52 AM
fodedave1989
10-26-2009 12:22 PM
Eddie1972
03-23-2009 09:27 PM
kylekip68
06-12-2004 03:04 PM
Quick Reply: 94' F-250 won't start
