351w oil pan what kind of sump?
With my Cleveland a rear sump was required. But assuming your motor mounts are already in place this could be tricky. A lot of people (including myself) move the cross member forward to center the wheels in the fenders. If you do need a rear sump you will need the corresponding pickup tube for that pan.
It is easier to install a member and then install the mounts based on where it needs to be around the member.
jrockdiddy
01-22-2013 10:29 PM
CalebJns
03-31-2010 12:08 AM
Haaser
11-23-2005 07:06 PM
