1956 f6 tandem axle build
#76
I called a place in Iowa today and priced out a rear clip with air ride and air brakes off a 98 fraightliner twin screw, he wanted $3500. I would need to retro fit the brakes on the hole truck . I need to find a front end with air brakes too ! I m thinking a wreaked mid nineties donor that way I could get my diesel trans suspension and brakes
#77
I went and got my truck safety inspected today . The safety lane is in a big rig repair shop and the guys know me there , They always have stuff in the yard that just sits there broken! So I asked if they had a air ride twin screw rear clip some where and they said that they did have a 2003/2004 fraightliner Columbia !
I looked the truck over and found I could use a lot of parts off it ! I asked the guy helping me how much for the rear clip and he said he would ask the owner. So I was hanging out talking with some of the mechanics showing them my 56 build site , then they all started telling me what could work on my truck motor wise trains wise and.....then John looks at me and says " I know that your a builder ,we need some work done." I said ok show me what your thinking of...talked to the owner and looks like I may have a big trade in the works!
#78
Received 3,186 Likes
on
#79
#80
I think air-over-hydraulic is common however........ Look at what other trucks have. All the HD trucks I drove years ago [with air-brakes] didn't have front wheel brakes at all...
#81
on
#82
anything built after i think it was 1970 had to have front brakes.
the air front brakes work fine. the difference between front brakes and rears is that the fronts are set up to not lock up. some systems use a proportioning valve to limit air pressure, others by limiting brake travel.
The last one was a new 1978 IHC Transtar Eagle. It didn't have front wheel brakes. Maybe the owners removed them.
I think any new trucks with disc brakes have them though....
If I was going to replace (both front and rear) axles with modern ones, I would use (hydraulic, boosted) disc brakes all the way around!
#83
on
maybe it was 79 that they were required them. it has been a while though.
the 69 white 9000 did not have front brakes, the 79 autocar constructor did. these were both tractors too.
every tandem dump i have ever driven had front brakes, and my first ride, a 49 international L-190 had front brakes too. the 49 had air over hydraulic on the tractor, straight air for the trailers.
#86
#87
Received 1,384 Likes
on
#88
#89
#90
That might be required. The trucks I used to drive were much newer than 1970.
