F250 guys school me please...3000.00 Tow Rig
6.9 IDI made 170 hp @ 3,300 rpm and 338 peak torque @ 1,400 rpm.
7.3 IDI non-turbo made 185 hp @ 3,000 rpm and 360 peak torque @ 1,400 rpm.
93-94 Turbo 7.3 IDI made 190 hp @ 3,000 rpm. and 388 peak torque @ 1,400 rpm.
7.3 powerstroke made 275 hp @ 2,800 rpm and 525 peak torque @ 1,600 rpm. ( And I believe these number vary depending on year and such)
All these numbers are stock engines. So you start tuning and such and you can get decent mpg and power.
That truck looks alright. Low mileage, which can be good or bad. If it sat a long time with hardly any use you could be replacing parts and dried out rubber hoses and bushings. But, I wouldn't pay more than a couple grand for it. Maybe 2500 at the most.
As somebody that owns an F250 with a small block 351w (with just a couple performance upgrades) in it, I will say that for how I use it, the truck is awesome. A lot of people complain about how low powered the small blocks are, and often times it's because the rest of the truck isn't set up for what you're trying to do. My truck had 4.11 gears when I bought it and I was very happy with the towing power of it. It had no problem pulling a trailer with a big bronco on it a few times. However, I have driven a few 460 powered trucks, and they do feel like they have a little bit more power if they have 4.11 gears, but with 3.55 gears, I can't feel a difference between that and my truck.
But like some of these guys said, an F350 would probably be a better suited truck if your main purpose is going to be moving considerable amounts of weight with it.
I can't really help u on the 460 they will pull a house down I have a 96 f250 hd with the 5.8 liter and has 4-10 rears It will pull and haul just as good without eating a ton of fuel I get 12 to 15 depends on how hard I am on the throttle but the 2 460's I had where really terrible on fuel 8 miles to a gallon. Both where 4x4s one stick shift the other automatic same gas milage on both
#30
i just dont understand why people would want a gas over diesel for TOWING!. diesels just friggin love to work, run these idis at redline all day long. a member on the idi forum has an idi wrecker is 470k miles on it i believe.
also number 1 why diesel over gas..fuel savings, especially when towing! you can get youraelf a really nice idi for 3k.
but best bet for you-get in and drive both! the diesel will really shine with a load behind it i bet. i swear my truck feels better when its towing a car behind it.
No mater which power plant you choose, it will be a tough truck either way
