e4od
e4od
my 91 has developed a problem it seems to not have ist gear . the fluid is clean it still shifts but if left in drive it acts like its in two gears at once if pulled in manual low it pulls out in secound then shifts it still has reverse and od any suggestions would be fine I did code it it has trans temp senser code and o/d cancel switch code
