Putting an aftermarket radio in the 53...but where?
When I tried to mount a receiver in my dash, I quickly discovered there is almost nothing to attach to behind the front lip of the dash. This is one time where the 48-50's with the big underdash braces for the factory radio have a lot more possibilities.
I was a metal enclosure around 2 deep. It mounted to the bottom of the dash and then the front end of the deck mounted inside it obviously. This install pictured was done back in 03. At one time you could get them at Radio Shack. If I can find it I could send it to you if you wanted it. It might be a while although before I run across it. I still think an underdash mount of some form is the best way versus cutting up the dash. The reason I went glovebox with the latest install is I didnt want to cut up the dash or go overhead. My move was made necessary by my underperforming OLD AIR products unit.
If you are able to find a better picture that would be nice, I like the clean design and like it even more now that I know its metal so I would like to find one similar.
Im not going to cut up my dash and want my glovebox so this is the way for me to go.
#28
#29
I plan to use a radio which the face mounts (1 inch deep)while the body has a ten foot cord and can be mounted under the seat are where ever else you want.
Secretaudio SST is a hidden audio system that offers great flexibility for mounting in any type of vehicle. The main receiver/amplifier unit is usually hidden under the seat, or behind the dash. A 10ft cord from the Tuner/Amp plugs into a LCD display. The system can be operated from up to 40 feet away with the included RF (radio frequency remote.)
Included with the system is a flush mount bezel for console or dash mounting. The small dimensions of the flush mount system allow you to install the LCD display almost anywhere. The LCD also comes with a bracket mount for easy installation in the glove box, under the dash, in the ashtray, sun visor, console, or wherever you choose. Since its only 1" deep its especially handy for custom or street rod applications where there may be wiring or ducting routed behind the panels you wish to utilize for mounting. When your installation is finished you'll be rewarded with a quality professionally installed look.
Features:
AM/FM Stereo 200 watts 4x50
RF Remote Control (radio frequency no line of sight required, up to 40' range)
USB MP3/WMA Flash Drive Player
iPodฎ Direct Control Interface (built into tuner/amp unit) iPod Docking Cable Included. Does not work with iphone.
Alpha Numeric LCD Display Shows Artist / Song Titles for USB, iPodฎ and Satellite Radio
Satellite Radio Input (for optional Siriusฎ satellite radio tuner)
Direct CD Changer Control (CD changer optional)
Auxiliary Audio Input
4 Channel 3 Volt RCA Pre-Outs (for optional Amplifiers)
Subwoofer Pre-Out (for optional Subwoofer Amplifier)
Electronic Volume, Bass, Treble, Balance, Fader
5 Selectable iEQ Curves pop/jazz/classic/beat/rock
Zero Memory Current Draw (will not drain car battery when unit not in use)
24 Station pre-sets (18FM / 6AM)
10 Foot Cable from LCD Control Panel to Black Box (tuner/amp unit)
Power Antenna 12V Trigger Lead
Blue LED Illumination on Buttons and LCD Display with Contrast Control
LCD Flush Mount Trim Bezel Included
LCD Swivel Mount Bracket Included
Features:
